super55
- Joined
- Jan 27, 2012
- Messages
- 961
- Location
- Great North of Michigan
- Tractor
- Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had),
If this lady is set on not using any herbicide it can be done but be sure to inform her it will probably be about 4x the cost. If I was doing this pasture I would one. Plan on tilling/discing it all under to get the soil worked up. Than I would go ahead and plant a summer cover crop. Buckwheat is the first that comes to mind because it is extremely competitive and will usually out compete other vegetation and is easily killed off if mowed just prior to bloom. Oats are also very competitive.
After it is mowed just let it sit dormant. Don't do any tilling (all that will do is just re-expose dormant weed seeds again). Than in the fall when most plants are going dormant go ahead and frost seed your pasture with a fescue and wait until spring.
Unfortunately right now 1. really hard time to get pasture grasses established and 2. If you do plant in the spring it is almost impossible to get a clean pasture without the use of herbicides. To get a weed free plot without any herbicides you really need to start planning now for next years pasture.
