4bt cummins jeep tj
   / 4bt cummins jeep tj #1
dzljon
Advertiser
Jacksonville florida
none
I am building a cummins to be transplanted into my 2000 jeep, the piston have ceramic coated crowns, I installed a 3200 rpm gov spring, new fuel pin to go with the 40 hp injectors and stage 1 camshaft that came from acd engines
Here is a look at the progress
   / 4bt cummins jeep tj #3
That looks like a great project. I work for Victor based out of Denton, at least for the next 2 weeks. Is this going to be a rock crawler?
I look forward to seeing this project go forward. Please post a lot of pictures.
Made a little progress today
   / 4bt cummins jeep tj #5
I'm in to watch this one. Looks like a great project!
   / 4bt cummins jeep tj #7
Sounds like a great project. What are your plans for the jeep once it's done?
   / 4bt cummins jeep tj #8
Great project! Thanks for all the pix.
What tranny will you be using and will you have hood/axle clearance problems? Whats the difference between the stock cam and the Stage 1?
Looking forward to your progress.
Thanks.
Thanks.
The new cam is supposed to help with turbo spool up and keep egt's lower, I am also using the jeep nv3550 5 speed till I break it and will jump to the 4500 at that point, I estimate the power to be between 175 -200 hp and north of 400 tq which is more than enuff for the little tj imo
I am using a he341 charger from a early 2004 common 5.9 with a 9cm housing
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
1271 (A50490)
1271 (A50490)
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2009 Honda Pilot AWD SUV (A50324)
2009 Honda Pilot...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
