435 jd round baler tying 3' bales!!!!
   / 435 jd round baler tying 3' bales!!!! #1
carey324
dewy rose ga
john deer
Help please, our 435 is tying 3' bales. Any help on this please!!!
   / 435 jd round baler tying 3' bales!!!! #2
Has it ever worked right?
Do you have a operators manual?
Yes it did good last year, first bale throwed out a 3 footer will do it very time unless I push pump idler down to latch it back
Changed out the 5 springs today no difference
   / 435 jd round baler tying 3' bales!!!! #5
I have no experience operating a round baler, but there has to be an adjustment somewhere.
   / 435 jd round baler tying 3' bales!!!! #6
As I stated on another forum tying mechanism is not relatching after hay is ejected and rear gate is closed so as soon as enough hay enters chamber to tighten the twine pump belt spring to put tension on pump belt then pump starts turning causing twine arm to cycle.
FRONT MOUNT TANK (A58374)
FRONT MOUNT TANK...
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
5' ROLLING LADDER (A52708)
5' ROLLING LADDER...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
