New Non OEM Kubota BX25 Step Mat
   / New Non OEM Kubota BX25 Step Mat #1
Jj1479
Hooversville PA
Kubota bx25
Well after having my bx25 since January 2010 an after several times removing the step mat to clean underneath an to service several items my step mat has tears an was just warn out. So after calling my dealer an getting a price for a new step mat plus the 11 required clips I decided to go my own way an make something else fit.This is what I came up with. A new step mat from Lowes ($7.95) an New removable clips from Advance auto. All I did was traced it out with a silver pen an soapstone onto the back of the new one an carefully cut it out with a utility knife an a pair of tin snips . I think it looks better then the OEM one an I can remove these new clips ($3.89 for 6) with a Philips screwdriver when I want to clean under the mat. I'm taking back the push in clips in the white bags since I used the other ones but they are only 80cents at lowes for 2
4444.jpgimage3.jpgimage4.jpgimage9.jpgimage11.jpgimage12.jpgimage17.jpgimage18.jpgimage19.jpgimage20.jpg
   / New Non OEM Kubota BX25 Step Mat #2
Jj,
That looks MINT!! Sheer coincidence that the width and lenght are almost exact??? I notice that border is still intact. Nice Job!!
I was almost gonna pull the trigger on the new mat for my BX2370, but I like yours a lot better!!
Cheers,
BN
   / New Non OEM Kubota BX25 Step Mat #3
Looks better than the original!
Jj, That looks MINT!! Sheer coincidence that the width and lenght are almost exact??? I notice that border is still intact. Nice Job!! I was almost gonna pull the trigger on the new mat for my BX2370, but I like yours a lot better!! Cheers, BN
Thanks I only had to cut off 3/8 of an inch from the one side. I was lucky I guess.
   / New Non OEM Kubota BX25 Step Mat #6
Thats really cool you were able to find something big enough that you could cut to fit.
   / New Non OEM Kubota BX25 Step Mat #7
That looks very nice, I like it! Good job cutting and fitting it.
   / New Non OEM Kubota BX25 Step Mat #8
Nice work! I like the checkerboard pattern; the texture reminds me of the Rhinoliner in the bed of my pick up.
   / New Non OEM Kubota BX25 Step Mat #9
Nicely done and at a huge savings from OEM too! :thumbsup:
   / New Non OEM Kubota BX25 Step Mat #10
Excellent Job!
Thanks for the pictures
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 FORD F350 SERVICE TRUCK (A51222)
2015 FORD F350...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
