Rear mounted 7 way convenience plug plug question
   / Rear mounted 7 way convenience plug plug question #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
Most newer model tractor have the plug on the back pre wired ... my JD 5520 has and I plug my round baler into that ... handles tail lights and I guess sends info to the bale monitor in the cab???
Anyway if an older model tractor does not have said plug ... I assume just buy one and follow the wiring instructions ... Has anyone added a plug to an older tractor that doesn't have one? Any advise?
   / Rear mounted 7 way convenience plug plug question #2
7 terminal plug on rear of tractor has nothing to do with monitor on a JD rd baler as monitor has a separate power plug and baler monitor wiring.
Okay ... so then the plug on the baler that plugs into the tractor is simply for the baler taillights, brake lights and such ... really doesn't have to be plugged in?
   / Rear mounted 7 way convenience plug plug question #4
I googled and found an owners manual for your 5520. Below is a snippet of it showing the pinout of the outlet:
Thanks Chris ... Yep thats what I have on the JD 5520 ... I was thinking about putting one on my other tractor ... but as Don stated it actually doesn't do anything for the monitor so I'm thinking just go ahead and use the baler on that tractor with out adding the extra wiring.
2017 FREIGHTLINER CASCADIA WRECKED (A58214)
2017 FREIGHTLINER...
2271 (A58376)
2271 (A58376)
Deere 35P (A53317)
Deere 35P (A53317)
55-Gallon Drum of Komatsu Hydraulic Oil HO 56-HE (UNOPENED) (A59076)
55-Gallon Drum of...
2021 Bobcat E50 R2 Series Excavator w/ Push Blade & Hydro Thumb (A59213)
2021 Bobcat E50 R2...
2023 HELI CPYD25C FORKLIFT (A58216)
2023 HELI CPYD25C...
