4bt cummins jeep tj
   / 4bt cummins jeep tj
Added some color to the valve covers
Injection pump is installed
Started making a engine shroud
   / 4bt cummins jeep tj #24
What are you running in the TJ now??
   / 4bt cummins jeep tj #26
The 4.0L has very good low end torque. Not sure how much gain you'll feel. But then it depends on what your intent is. Are you gonna drive it on the hiway at all?
Stock is under 300 ft lbs this will be north of 400 and get 20+ mpg
   / 4bt cummins jeep tj #28
Don't get too wrapped up in numbers. Are going to hiway drive it at all??
Here is the cummi s I put in my f250, and it out performs the 7.3 on every level, I will be honest I hate gas motors an I hate any v gas motor even more and the v configuration diesel in pickups suck as well
   / 4bt cummins jeep tj #30
I run Jeeps and 4 wheel almost every weekend. I also road trip every year, covering 3000 miles or more each trip. Just trying to help you out. I've wheeled several times with Jeeps equipped with the 4BT. Not sure what your Cummins equipped F250 has to do with the Jeep project.
So are you going to drive this Jeep on the hiway or not??
Quick Attach 84" Push Blade (A50121)
Quick Attach 84"...
Deere 9970 Cotton Picker (A52748)
Deere 9970 Cotton...
Tires (A50322)
Tires (A50322)
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
(30) 24-A Macro Bins (A50121)
(30) 24-A Macro...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
