Educate me on battery choices
   / Educate me on battery choices #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
I've got a Telsta A28D bucket on a 2001 Ford F450. The hydraulics are powered by one big battery. I've crossed the current battery to a NAPA 7271 FT, a 1425 (@ 0 degrees F) CCA battery. 440 minute reserve capacity. This would appear to me to be a starting battery for commercial applications.
Would I be better off to look for some type of deep cycle for this application? Something similar to this? MK Battery | 12 Volt 200 AH Deep Cycle AGM RV & Marine Battery or this? http://www.napaonline.com/Catalog/C...y-Marine-RV-Deep-Cycle/_/R-NBE8276_0353642380
For the money that these things cost, I'd rather not experiment and would like to get it right the first time. Current battery tested OK last fall and was on a trickle charge all winter, but it almost left me in the air yesterday without really a lot of use time on it.
I checked my Telsta service and parts manual over but no mention of battery size or type for these units is mentioned. If anyone with electrical knowledge of these types of applications could help me out I'd appreciate it.
   / Educate me on battery choices #3
I have a group 31 Odyssey battery with 1200 CCA in my tractor. It always has sufficient power to go the distance and has never let me down.
   / Educate me on battery choices #4
There are three common battery chemistries, each takes a UNIQUE charging profile, since almost all engines are supplied with alternators designed for wet lead-acid batteries, you will get the best life from a quality battery of that type, period.
Now, the question is what is a "quality" wet lead-acid battery? That's opening Pandora's box....
In the US, there are essentially three battery manufacturers: 1) Johnson Controls (most OEMs), 2) Exide (most aftermarket and private label) and 3) Deka (East Penn, mostly their own label).
Of those three, based on 25 years of maintaining large fleets, I would go Deka or Johnson Controls (Interstate label).
HOWEVER, you stated that this battery "powers" the bucket functions on your truck, if that is true and you are not using the battery for starting all of the above are completely irrelevant because you NEED a "Deep-Cycle" battery and NOT and "SLA" (Starting, Lighting, Accessory) type as found in most vehicles. In the case of deep-cycle, get a 12V Trojan Gp 31 (or two) and be DONE with it.
Btw, there is no such thing as a "combination starting/deep cycle" battery, that's like saying you have a combination gas/diesel engine and it works well on both fuels..... NOT.
   / Educate me on battery choices #5
True enough, but AGM batteries, developed for aircraft use, will typically last many more charge cycles than a flooded lead acid battery, especially if there are extended loads on it, like kids opening and closing the doors of a minivan while watching movies and charging their phones: which is why we now have a $200 AGM....
This is a separate battery that powers the lift. The V10 in the truck has it's own battery. There's a switch in the cab to activate power to the lift. The way it's been explained to me, when that switch is on, the lift battery powers the lift and is isolated from the rest of the charging system so that the truck battery doesn't get sapped. When the lift switch is off, the truck alternator charges that battery.
I'm kind of leaning toward the NAPA deep cycle (I believe Deka makes their batteries) in my earlier link, but the listing doesn't show amp hours.
   / Educate me on battery choices #7
AFAIK, all NAPA batteries are Exide and I'm not a fan.
You need about 220 A-Hr of capacity and what you describe makes total sense.
BTW, ANY battery that advertises a "CCA" rating, IS NOT a "deep cycle" battery.
   / Educate me on battery choices #8
What kind of trickle charger? If it wasnt the type that monitors charge like a "Battery Tender" it probably fried that battery over the winter.
Also, you will want to look into how your truck charges the aux batt. If it just puts it across your truck battery in parallel there is no guarantee it is charging correctly. ... A new batt will suffer some but accommodate the issue. As the batt declines [prematurely] the charge quality will suffer increasingly.
Your best bet is to use the aux batt as youve stated, but equip it with some extra leads that will allow you to plug it into a battery tender every nite. The batt tender should bring the aux batt to full charge level overnite. If it reaches it early it will reduce charge output to a safe maintenance level that can be continued indefinitely.
Pretty sure that Eastern Penn (Deka) makes NAPA's batteries. Whether or not that's the same as Exide, I can't say.
I agree with your statement about amp hours. That's why I wish I could find the specs on a NAPA 8276. The description shows it as a deep cycle, but only shows CCA, not amp hours. Confusing me a little bit there.
Should have mentioned in the original post - current battery is a Deka 908 DFT. I have no idea if that's a correct battery or if the selling dealer installed it as a cheaper way out.
I'm wondering if a high quality, higher amp hour golf cart battery is the best way out or if the battery has to be physically as large as the current one?
   / Educate me on battery choices #10
I could not, initially figure out how a 'tractor bucket' would fit/ be of any use on a Ford 450 truck.:confused2: Then I read your equipment list, and figured out it was 'slang' for aerial lift bucket truck!:duh:
Here's how I'd approach your battery choices. Find out what battery was OEM to that application, then, taking into account what improvements have occurred since 2001 in battery technology, adjust accordingly. When I had my foreign auto repair shop, I was an Interstate battery dealer. I just found out when taking a battery to them recently, to be load tested, that they sell blemished batteries for about 1/2 of retail, AND they also sell used batteries? Not sure about wanting a 'used' batt, but 1/2 price brand new blems, with maybe a scratch on the outer casing; bring them on!
So, if you can find, by a search like this, for example, you could at least know whether deep cycle or starting is best suited to the wiring on your bucket truck.
https://www.google.com/search?q=200...rome..69i57&sourceid=chrome&es_sm=93&ie=UTF-8
I'm betting deep cycle, like on a boat application, where the battery that gets the lesser amount of use is deep cycle, for occasional use, like trolling motor, 'house' functions, like lights, bilge, etc. The outboard would get high CCA for engine start, thus a 'starting battery'.
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Enmark Z Spray (A53316)
Enmark Z Spray...
2000 Case 590 SL Backhoe Loader (A59814)
2000 Case 590 SL...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
SUV (A59231)
SUV (A59231)
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
