Drain Tiling Field?
   / Drain Tiling Field? #11
Here are the average custom rates (and ranges) for tiling in Iowa in 2015 (from a pdf file -- Google Iowa State custom farm rates)
Tiling, tiling machine (ex. materials), / ft. 1.15 0.55 - 2.00
Tiling, tile plow (ex. materials), / foot 0.76 0.40 - 1.00
As mentioned, the NRCS staff at your local USDA office will provide expert advice at no charge to you.
Steve
   / Drain Tiling Field? #12
Field tile can be a great improvement for a feild or just a low spot. An extension agent or NRCS can tell you how well it will work in your soils.
If your going to hire it out you don't have to know how to install but some important questions to ask are.
1. Are they using a main? If so what size?
2. What slope (grade) will they use?
3. Laser or GPS? You want one of these.
4. Spacing in relation to the depth?
Mains aren't necessarily but it allows you to only have one exit. Less to maintain. Make sure it's atleast one size bigger than the tile. You don't want a 4" main with 4" tile. You want a 5 or 6" inch main. Probably a 6. Depends on how large of acreage your draining.
Don't lay it too flat. It won't keep the dirt flushed out. 2% is good for my area. Your maybe different.
GPS is supposed to be better than laser but I've never used it. When I was tilling it was all laser.
For my area a inch of depth is good for a foot of pull. So as long as you are over 30" you can go with a 60 foot spacing.
Also for my area it's going to be about a dollar/ foot for someone to lay tile.
   / Drain Tiling Field? #14
Excluding cost of the tile? Steve
You know I'm not sure. But I was thinking that the last guy I talked to acted like it included the tile. If I see him again soon I'll try to clarify.
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2019 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A52705)
2019 CATERPILLAR...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2010 International Prostar (A47477)
2010 International...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
