Oil DRAIN PLUG TORQUE
/ Oil DRAIN PLUG TORQUE #1
marshallcro
Member
Stanfordville,ny
John Deere 3720, Farmall Cub, Bobcat 3400
Would anyone know the drain plug torque value for a JD 3720 ?
Thanks in advance.
/ Oil DRAIN PLUG TORQUE #2
Snug it with a box wrench, then another 1/4 turn. Don't over tighten oil or transmission drain plugs, you don't ever want them to strip out.
/ Oil DRAIN PLUG TORQUE #3
I always tighten drain plugs to right before the point where they will strip and stop there.....
/ Oil DRAIN PLUG TORQUE #4
Sorry I can't provide a torque spec, but this is what I do on drain plugs, not that I have any credentials. I use a 1/4 inch ratchet with the 1/4 to 1/2 adapter. Most drain plugs are larger than the 1/4 inch sockets. I then catch up close to the ratchet head with hand, then tighten snugly in this manner. It is just slightly more torque than you would normally apply with a nutdriver. Just a little bit more.
/ Oil DRAIN PLUG TORQUE #5
How big is the threaded portion. How deep is the thread engagement into the oil pan? Are the female threads aluminum or steel? ... I ask because the drainplug on a tractor may be exposed to projectiles from debris hit by an implement, which could jar a marginally tightened plug to a loose state from which it would slowly spin out.
,,,,Hopefully your plug arrangement is robust enuf to easily support 20 or 30 ft-lb in order to resist accidental loosening.
larry
/ Oil DRAIN PLUG TORQUE #6
Your only trying to hold the liquid in the pan in, which ISN'T under pressure. You're NOT trying to hold the engine together. Go lightly on the torque.
DEWFPO
/ Oil DRAIN PLUG TORQUE #7
I haven't torqued a oil pan drain plug, or even considered it, on any vehicle, heavy truck, ag tractor, or construction equipment since I started turning wrenches on stuff in the 60's. But you hear something new every day. But for several years, I have just avoided the whole thing and put Fumoto drain valves on my engine oil pans. Everything from my Jeep and pickup to my semi to my tractor. Sure makes life simpler.
/ Oil DRAIN PLUG TORQUE #8
Thanks in advance.
I have already stripped both sides of alluminum oil pan on my Mahindra 4110. 1st one 6yrs ago, 2nd one last year - thank God they were short plugs , went to auto parts store and purchased a longer plug each time -- the longer plugs caught the tread deeper in the hole. I use a craftsnan 1/2 torque wrench at no more than 17/18 lbs. Before that I used snug + 1/4 turn like I did on my autos steel pans
/ Oil DRAIN PLUG TORQUE #9
Excellent point - aluminum pans are nowhere as forgiving as steel.
Rgds, D.
/ Oil DRAIN PLUG TORQUE #10
If it's a tapered thread plug, I could see using the 1/8 or 1/4 turn (at most) after lightly snug. But many plugs have a shoulder that contacts the pan and relies on that to seal. Once that type is snug, I think another 1/4 turn into aluminum is asking for trouble.
/ Oil DRAIN PLUG TORQUE #12
I'm a firm believer in using torque wrenches on everything.
My advice to the OP is to call a dealer service department and find out, like i do when i need torque specs.
/ Oil DRAIN PLUG TORQUE #14
[QU this pointOTE=Ford850;4150280]Yep. And 1/4 after "snug". What exactly is "snug"?[/QUOTE]
When you visually see that the bolt is up against the pan that's snug usually for me .
it's finger tightening to this point then I put a wrench on it.. Can u tell me EXACTLY what a
Pinch of salt is :confused3:
/ Oil DRAIN PLUG TORQUE #15
Yes, a 1/4 turn beyond 'snug' could be too much for an aluminum pan with a steel bolt. So if pan won't hold a magnet, then go 1/8 turn beyond finger tightened by human, no gorillas allowed.:laughing: use only a 6" box wrench no ratchets or breaker bars allowed.
Snug is: secure - https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=what is snug
Pinch of salt: smaller than a teaspoon full, what fits between a human forefinger and a thumb, see note re: gorillas.
/ Oil DRAIN PLUG TORQUE #16
I could not have said it more "accurately", "exactly" what I thought, you are "spot on" :thumbsup: with science behind us how could anybody make a mistake :confused2: just "joshin ya".... Seriously - Have a safe day out there with your MACHINES
/ Oil DRAIN PLUG TORQUE #17
Tighten until stripped and back off 1/4 turn..:laughing:
/ Oil DRAIN PLUG TORQUE #18
DEWFPO
Wise advice here.
This is right because plugs are a "seat of the pants" thing that is done by either feel or torque wrench. Experience teaches how tight that tight actually is and if one is a newbie it's better to start with a torque wrench than guess it wrong.
Best answer and probably spoken from experience. screw up once and you will forever know how tight "tight" is.
Good thread for lots of people.
/ Oil DRAIN PLUG TORQUE #19
That is what I usually do.. :D
Funny story: I was replacing the side window glass in my 1978 Grenada.. You can tell this story happened a long time ago.. anyway I was tightening the retaining bolt that goes thru the hole in the glass and holds the glass to the raising mechanism. Just exactly how tight should that bolt be? Well, the first one I tightened until I hearda bang sound and the glass disappeared right before my eyes. One second it was there, and the next second it was gone.
I procured the vacuum cleaner and vacuumed up all of the window glass bits now lying on the bottom of the door.
On the second window glass I purchased, (that was the last one they had on hand), I tightened it a bit less, Uh, sort of "snug" plus a bit more, but not "tight". That seemed to work. Lesson learned.
/ Oil DRAIN PLUG TORQUE #20
Oh, so it's 'gonna be a case of who did the dumbest tightening story, eh?:laughing: I can top yours, KOua!
I tried to drill a hole in one of the old style corner vent windows on an old Volvo so I could bolt in the newer type latch that went threw the hole in the updated windows, when they upgraded from a glued on/falls off latch. I did this on the parkay floor of my then girlfriend's apartment, 'cause I couldn't get enough pressure on the glass with the drill tip at the dining table.:confused3:
Can't remember if I got the hole through, but I'll never forget the sound of the glass exploding a few minutes after I finished whatever it was I thought I was doing to the tempered glass!:duh:
I think if only for a bigger drill, or freezing the glass first, I could have made it!:confused2:
Never did get to snug up that bolt.
Regarding actual drain pan bolts, the only bolts I found loose on my DK-35 Kioti, were the 2 oil drain bolts. They are steel on a 'double' aluminum pan sections. I checked with my dealer and he said definitely do not overtighten the bolts or they'll be replacing the pan for me. They omitted mentioning what overtightened would look like, but now that I mention it, they musta' meant 1/4 turn past stripped out! When I did the first oil change those bolts were barely beyond finger tight when I went to remove the oil. I very carefully tightened them just a smidge beyond snug.
20 gal Oil Collector (A66408)
20 gal Oil...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
1982 Doolittle Gooseneck Trailer (A66285)
1982 Doolittle...
