Ahp Tig welder 200x
   / Ahp Tig welder 200x #71
Like everyone else said clean with Acetone and stainless brush. Plus heat it up to 400-500 degrees to burn off any embedded oil and dirt.
And you may want to try running bead with no filler. This will leave a charred mess. Then brush again, and run a bead again. Repeat utill the soot goes away.
Somewhere Weldingtipsandtricks.com has a video showing this technique.
   / Ahp Tig welder 200x #72
Yep, acetone, and a new stainless steel wire brush. And never use that stainless steel wire brush on anything but aluminum again!
I use a big Sharpie pen and write on my wire brush handles... 'Aluminum Only'. There are a few other things I should use the big Sharpie for too... like our wedding anniversary... wife's B-day... Valentine's day... but I don't know where to write that so i will see it when it is time. :laughing:
   / Ahp Tig welder 200x #73
Mark. Do you have a spare room for guests? Perhaps on the bed's headboard ...?
Terry
   / Ahp Tig welder 200x #74
Here's some experimentation on fairly dirty 1/8" plate to test the effectiveness of brushing with the dedicated SS brush. Main amps 87, start amps 25, end amps 15, AC frequency 100hz, AC balance 30%, and post flow 4 sec. Weld one was moderate brushing, weld 2 no brushing and welds 3 & 4 vigorous brushing. Weld 4 & 5 was practice resuming a bead after cool down and I built it up on the end of weld 4 for that reason. Next time I'll turn the amps up a bit to account for the extra thickness:
   / Ahp Tig welder 200x #75
OK, my welds are looking tons better as I am learning to keep the torch steady and close to the work. Here is some Dr Pepper can welding just to test the machine on low (very low) settings. For this I found the AC frequency needs to be at about 30hz, amps at 20:
I made a small device out of a piece of broken fiberglass shovel that lets me advance the filler with one finger. Also keeps bare hand completely insulated from the filler. This helps me a lot as advancing filler with a glove on was driving me nuts:
   / Ahp Tig welder 200x #76
If your machine has wave balance you can mess with that to get good cleaning. Too much and it will eat tungsten so be aware.. Dr.Pepper can is now ready for a nice stack of dimes bead. Nasty coating on the cans.
   / Ahp Tig welder 200x #77
Yes it has AC balance which I have set low. In order to actually lay a bead I need to devise a way to rotate the can slowly on demand. This was mainly to see if I could get puddles started on the can and add some filler without punching through.
   / Ahp Tig welder 200x #80
Fawken, you can get by with a light duty bench positioner for under $500. U can buy a lot of Dr Pepper with the G note you save. :D:D
Terry
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
Fast 9613N 1300 Gallon Sprayer (A57148)
Fast 9613N 1300...
Skid Steer 66in Skeleton Bucket (New/Unused) (A59225)
Skid Steer 66in...
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
