Everything Attachments Box Blade?
   / Everything Attachments Box Blade? #1
Gooch79
Graham, NC
Kioti DK40se HST
I am checking out box blades from Everything Attachments... The "Xtreme Duty Compact Tractor Box Blade," states that it is for tractors around 35hp. I have a Kioti DK40se with 41hp. Should I get the "XTreme Duty Box Blade For Utility Tractors With 30-70 HP," instead? Does anyone have a DK40se with any EA products? I am looking at landscape rakes too.
   / Everything Attachments Box Blade? #2
I don't know if this helps, but I just ordered the 72" XTreme Duty Box Blade For Utility Tractors With 30-70 HP for my 52 hp Kubota. I also have the 72" EA landscape rake that I was just using today, and I love it. My experience with EA implements has been very positive, and find them to be much better than most name brands out there. I think you will be happy with this box blade.
Which rake did you buy?
   / Everything Attachments Box Blade? #4
I have a 78" EA box blade on my DK40se, only have about 15 hrs on it, so far it has worked great. I don't remember which version I have and I won't be able to check until Friday. I put a level on it to help me with grading of our road, T-N-T really helps being able to fine tune the leveling on the fly. The only change I would like to see is a little more distance between the frame that holds the scarifiers and the back plate that mounts the cutting edge. When cutting level all is fine, but when I cut at a angle to put a crown on the road, dirt gets jammed between frame and the back plate and doesn't flow well to the other side. I have also had a few occasions where I wish the BB was a little heavier to dig in better, just means I have to take another pass. For the value.. the EA BB is hard to beat.
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2021 CATERPILLAR D5 LGP HIGH TRACK DOZER (A60429)
2021 CATERPILLAR...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
