Firewood - Wood Splitter - Not Tractor Attached - Whats best?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #71
That's the video I was referring to but not the shootout for the magazine. I'm not going to copy/paste from the article but I will post the results.
Time was how long each splitter took to split 1.5 ricks (one rick is a 12 foot by 4 foot of 16 inch long firewood)
Timberwolf TW5FC 44 minutes, 13 seconds (2.0 ricks/hour)
Super Split HD 30 minutes, 49 seconds (2.9 ricks/hour)
The TW has a 6-second cycle time, a work table and used a 6-way wedge.
Link to sawmillmag: https://www.sawmillmag.com/app/home/index See "back issues" and look for the Oct/Nov 2009 issue
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #72
aaaaaaw SS owners love to post that vid BUT, comparing a SS WITH a table, to a TW WITHOUT a table, makes for a huge stacked deck for the SS... Especially, with easy to split wood...
I agree. Life is to short to split wood without a table. I'd recommend it for any splitter. A lifter would be nice for big pieces but I use the tractor bucket, and a wheelbarrow.
Again, if you focus on the 1-10% toughest-to-split pieces on your lot, you are going to wind up with a hydraulic, with a cycle time of 9-15 seconds. And if you focus on the 90-99% of the "normal" wood, you're going to buy a KE with a cycle time of 2-4 seconds. We've got plenty of wood so I ignore the stumps and crotches.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #74
In the past I would just noodle crotches with my saw. But recently I had a lot of white oak to split, and it had a ton of burls/knobs along the entire tree. Every round was a challenge, almost like every one was a crotch.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #75
A little off topic, but I find it terribly ironic (and a bit comical) that the people who live in southern climates have the milder winters, but have access to the biggest, heaviest, hardest, highest BTU trees, therefore, needing the bigger, tougher splitters. Meanwhile, up in northern Minnesota and Canada, we have long periods of below zero winters, but have to heat with these mild burning, spindly, stunted excuses for trees. We (or, at least, I) can easily get along with 22-ton machines.
Anyone else notice this? :confused3:
From the comments and videos I'm sure I could get along well with a Super Split or 22 ton hydraulic splitter. Trees take a long time in the northern states to reach any size and they usually don't get it. :) I cull junk and release trees and use quite a bit of limb wood too. None of it is big diameter stuff. Over 12" dbh would be unusual.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #76
Population density and the need to keep warm...
When I was stationed in Germany we hated to take tracked vehicles though their "forests" as there were multiple sets of stumps that would pop a track pin when turning. Our lot in NH has two sets of stumps and was partially logged in the 50's and again in the 80's.
We burn almost all hardwoods and the Ash, Paper Birch, Red Oak and Sugar Maple is all good to excellent. We also burn a little Hemlock and it burns fast and well, with little ash, no coals and less heat. But folks in the high plains happily burn it because that's what they have . Heat output is pretty directly proportional to mass.
Waaaay off topic, but the USS Constitution used Live Oak in construction. This was very hard wood, but there is more to her nickname of Old Ironsides.
An American Naval Strategist named Mahan made the point that the US Navy would have to operate as raiders: they were going to have to win one-on-one battles on the high seas, but run from large British fleets. So Constitution and her sister ships were larger, with heavier guns and framework than most British Frigates. She was faster than the largest British ships, which wee heavily armed to provide firepower in fleet actions. So that was part of her success.
There were several other advances that were Top Secret in the day. Her masts were made in sections, so that of one was shot up it could be replaced: the Brits used whole tree sections. Constitution also had a set of longitudinal stringers which prevented "hogging." This latter technology was only discovered in her last rebuild in the 1990's. She is in drydock as we speak and will not make her usual July 4th turn-around this year.
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #77
And again, every 9 sec or less, I get FOUR splits, not just ONE...
SR
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #78
And the price of that unit is?
And do they sell the add on head separately? No reason I couldn't use it on a KE for what we are splitting. Seems like a worthwhile add-on.
How do you adjust the height for different-sized rounds?
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #79
I paid $3,500.00 for mine and it INCLUDED the 4-way wedge and table grate... As I remember, a SS HD was around $3,000.00
Optional, I could have got the hydraulic option that allows you to adjust the height of the 4-way... After looking a 4-way over, I could see that it has two heights built in, and that was all I needed to get the size splits I wanted.
You put a TW 4-way on your bam bam and you will need a new rack and pinion in pretty short order... lol
SR
   / Firewood - Wood Splitter - Not Tractor Attached - Whats best? #80
SR
Wouldn't that be every 18 seconds? (cycle time is 9 seconds to fully extend the ram and another 9 to retract it)
2013 ISUZU NPR 16FT BOX TRUCK (A52141)
2013 ISUZU NPR...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
New Edco Hand 8" Post Hole Digger (A50774)
New Edco Hand 8"...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
