Finding V Bolts
   / Finding V Bolts #1
Kodiak45
Gold Member
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
I need to find some V Bolts for my 3.5" toolbar. I have no idea where to find these things. They cant be that custom of a bolt. Anybody got any ideas? The toolbar is for my allis 74 planters.
   / Finding V Bolts #2
In recent years I've seen more V-blocks and V-straps than V-bolts on toolbars. That way normal bolts can be used.
Like the bottom part on these two clamps. (First photo I found)
Bruce
   / Finding V Bolts
I cant even find the clamps or straps like you showed.. help
   / Finding V Bolts #6
For clamps, I would get some thick wall rectangular tube and cut some out, or have them made. Cut in half, drill, notch.
Or have some V-bolts made, or bend some myself from rod after threading the ends, or maybe use threaded rod.
This is the kind of thing any agricultural area machine shop/welding shop should stock or make as needed.
Or even maybe there is a professional or hobby blacksmith nearby?
Bruce
   / Finding V Bolts #7
The clamps pictured above can also be commonly referred to as T bar clamps (yes, t for tool). They can still be bought from most ag dealerships (although not always a stocked item - these are not as common as they where in the 60's) , as can the bolts you are looking for. They will commonly be referred to as just a U bolt w/ a V bend. Good Luck
   / Finding V Bolts #8
Bruce
Man, that is a neat idea! I'm going to keep that one on my mind because it may be helpful in the future projects I work on.
Thank you Bruce. :D
   / Finding V Bolts #9
You can also google "diamond toolbar clamp" you will get quite a few results.
iDrive TDS-2010H...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
