I have owned a Split fire for about 3 years now. I really like it,and have had no problems at all with it. Here is a review I did in March about the Super Split and the Split Fire at my GTG.
"We had a Super Split and a Split Fire at our GTG in March. I liked the height of the Super Split and the large table. It is truly a nice machine to run.Pros where the height being comfortable to split,but that also required you to pick the rounds up higher. It is also next to impossible to tow in that configuration.It is extremely easy to tip,even wheeling it around by hand it is top heavy. The guys that brought it had it upset when they loaded it in the back of the truck. And we had trouble when we re loaded it for the trip home. It has to be tied down good to keep it from tipping over in the back of the truck or trailer.When it was set up on a level spot it was nice. All of the wood that it split could easily been put on a conveyor. We split nothing but cherry,contrary to what I have read it will not split every thing. Sometimes an extra hit will do it,sometimes you have to beat the log off. To be far,this does not happen often but it happens.Over all its a great splitter,but it does not split anything you throw at it.Also at times a piece of wood would really get thrown out.Kinda like hitting a round with an axe and have the wood go flying.
The split fire like the super split is well made. The split fire splits in both directions and has a four way wedge that the super split does not. I do believe from our experience that the split fire will keep up and in cases be faster then the super split.Wood the super split would not split the split fire easily split. Cons.The split fire we had was set up to tow on the road,that is great for going longer distances. But when stopped it is to low to split comfortably. This was rectified by putting the splitter on 2 car ramps and the front on a block. It was quit easy to use after that,and was as comfortable as the super split. The back and forth splitting was fast and nice,however this does not allow the wood to go one direction for a conveyer or pile. You basically got to throw all the splits off by hand.The table also is not as large as the super split.This can be changed,you can make it longer. I do believe that you can get a log lift for both splitters. As I get older this might be nice.However I just put large rounds in my loader bucket and slide them off at the same level as either splitter.
Both were very economical on fuel,both had their advantages. This particular day the split fire split all that was thrown at it,the super split did not. Cost wise they were both very close to $3000.00. Personally I would be happy with either unit,they both had pros and cons.
Splitting 15 to 20 cords or less a year I would probably choose the split fire. Its a great splitter and seems to be tough as nails. It also handled the knotty wood better.
Over 15 to 20 cords I would probably choose the super split,especially if I had access to a lot of straight grained wood. It is fun to run and it pushes the wood one way,fast.So you can put the wood on a conveyor easily. I would keep a good hydraulic splitter around for the hard to split rounds.
I tried to be as far as I could about this review. I actually like both of these splitters,but neither is perfect."
Hope this helps. Dave
