Best way to engage rotary cutter
   / Best way to engage rotary cutter #1
MyOutdoors
Member
Lempster, NH
Branson 3120
I just got a new rotary/brush cutter with a slip clutch. I adjusted the slip clutch and just want to know the best way to start these up. I'm running a branson 3120 with pto switch. I know to run it 540 rpms but it seems to jump and bang around when I 1st engage it.
Should I keep the rpms down to engage it with the switch, then ramp it up to 540? Or are they ok to just start at 540?
   / Best way to engage rotary cutter #3
Common sense dictates to start it slowly and work up to 540. There's a flywheel under there you have to get going. Little banging and clanking as the blades sling out is normal.
   / Best way to engage rotary cutter #4
Engage at low RPMs, then increase.
Steve
This - and do the opposite when you can to shut it off, ease the throttle down to fast idle then disengage.
   / Best way to engage rotary cutter #5
Also, if your unit has a brake to stop the blades when the PTO input is off, you should slow the motor down to low RPMs before disengaging.
prs
   / Best way to engage rotary cutter #6
Can't add anything to that; all good advice.:)
   / Best way to engage rotary cutter #7
Yep, all good advice. I find that I can start mine at an idle, and that is what I do. I also come to an idle before disengaging.
Will
   / Best way to engage rotary cutter #8
ONE THING I FORGOT!!!!! ALWAYS raise it up and wait 10-15 seconds before you engage it!
   / Best way to engage rotary cutter #9
All great advice above. I don't know about your tractor but on both of mine I can ease the pto lever very slowly at a low rpm and the pto gradually takes hold without much shaking etc. .
   / Best way to engage rotary cutter #10
A lot of tractors with an independent PTO now no longer have a lever for engagement, my newest has an on/off knob.
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
196046 (A50459)
196046 (A50459)
Avco / New Idea Hayrake (A50515)
Avco / New Idea...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
