Oil & Fuel 1996 L5450 Transmission/ Hydraulic Fluid?
   / 1996 L5450 Transmission/ Hydraulic Fluid? #1
sflight
Kubota L5450
What kind of transmission/hydraulic fluid do all you L5450 owners use. Mine is a 1996 and of course the Kubota dealership is saying I should only use the Kubota UDT fluid which is around $85 for a 5 gallon bucket. I used the case hy- tran last time I changed the fluid but that stuff is way expensive and now hard to find since I moved. Is there a cheaper alternative that works without sacrificing protection? Thanks for any info you can provide.
   / 1996 L5450 Transmission/ Hydraulic Fluid? #2
Tractor supply sells a utd replacement. it more expencive of there 3 for about $45.00 udt is listed on the back of the 5 gal container.
   / 1996 L5450 Transmission/ Hydraulic Fluid? #3
Try Sam's for hydro fluid if you want the one of least expensive.
   / 1996 L5450 Transmission/ Hydraulic Fluid? #4
I use Walmart hyd fluid in my gear rigs, including the L5450 with EC hydraulic shuttle. Their Super tech Fluid has worked well, about $8.50/gal.
Thanks all. Went ahead with the super tech stuff from walmart. Everything seems to work fine but the hydraulic filter light has not gone out yet. Do you all know if that takes awhile to go out? Also, the l540 only has 1 hydraulic filter, right? It does not have an internal screen filter? The tractors either have one or the other depending on year, right?
   / 1996 L5450 Transmission/ Hydraulic Fluid? #6
The parts diagram shows a filter on the suction side with a center-mounted magnet. On my rigs the light may light on winter start-up but it goes out fairly soon. If it's on this time of year the level is low or there's a switch issue.
  • L5450 hyd suction.pdf
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2010 DOOSAN G25 GENERATOR (A53843)
2010 DOOSAN G25...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2005 Kaufman Trailers Trailer, VIN # 15XFW53265L001140 (A53421)
2005 Kaufman...
