Oil & Fuel 1996 L5450 Transmission/ Hydraulic Fluid?
   / 1996 L5450 Transmission/ Hydraulic Fluid? #1
sflight
Kubota L5450
What kind of transmission/hydraulic fluid do all you L5450 owners use. Mine is a 1996 and of course the Kubota dealership is saying I should only use the Kubota UDT fluid which is around $85 for a 5 gallon bucket. I used the case hy- tran last time I changed the fluid but that stuff is way expensive and now hard to find since I moved. Is there a cheaper alternative that works without sacrificing protection? Thanks for any info you can provide.
   / 1996 L5450 Transmission/ Hydraulic Fluid? #2
Tractor supply sells a utd replacement. it more expencive of there 3 for about $45.00 udt is listed on the back of the 5 gal container.
   / 1996 L5450 Transmission/ Hydraulic Fluid? #3
Try Sam's for hydro fluid if you want the one of least expensive.
   / 1996 L5450 Transmission/ Hydraulic Fluid? #4
I use Walmart hyd fluid in my gear rigs, including the L5450 with EC hydraulic shuttle. Their Super tech Fluid has worked well, about $8.50/gal.
Thanks all. Went ahead with the super tech stuff from walmart. Everything seems to work fine but the hydraulic filter light has not gone out yet. Do you all know if that takes awhile to go out? Also, the l540 only has 1 hydraulic filter, right? It does not have an internal screen filter? The tractors either have one or the other depending on year, right?
   / 1996 L5450 Transmission/ Hydraulic Fluid? #6
The parts diagram shows a filter on the suction side with a center-mounted magnet. On my rigs the light may light on winter start-up but it goes out fairly soon. If it's on this time of year the level is low or there's a switch issue.
  • L5450 hyd suction.pdf
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
