Add a rear remote to a Kubota L4310
   / Add a rear remote to a Kubota L4310
Why all the recommendations to jury-rig aftermarket valves when factor remotes are available?
Just go get what you need from Kubota. They bolt right up and look like they belong (because they do). I can see aftermarket make-shift solutions when that is the only thing available... but when there is a factor valve designed for your tractor, that is going to be the best solution.
Because 2 remotes from kubota is about $1700. A 2 spool valve from surplus is about 210 or 220. Drill a few mounting holes, make a bracket or so, and a few hoses later, viola! Got to be cheaper then $1700.
Here is how kubota does it. You can get some ideals from it and see where they pick up hyd.
Thanks for the file but I can't get it to open. Could you send it in a pm or an email maybe?
   / Add a rear remote to a Kubota L4310 #33
I couldn't find where to add it in PM, if you send me your email by PM me and I'll be glad to send it.
   / Add a rear remote to a Kubota L4310 #34
Some of the good folks here on TBN want you to spend lots of money for something that should be less.
However if you have the know how and want to spend less, you will look at Surplus or where ever and purchase exactly what you need as to the type of spools required and how many spools, and you actually know how everything works.
T-N-T requires two spools, one with float and one more for whatever, would be good.
It should not take much to find a good location for the valve and to connect things up right for a fully operational setup that looks good.
If you look at some of the past installs you will see some good setups.
Factory install is not necessarily the way to go.
   / Add a rear remote to a Kubota L4310 #35
Email is on the way, hope it gives you some ideals.
   / Add a rear remote to a Kubota L4310 #37
Does your tractor have a loader and hyd block?
If so, then remove the PB hose on the hyd block and connect the PB line to the new valve, and then connect the PB from the remote valve back to the port on the hyd block.
The valves should now be n series for a complete flow path.
All tank lines go to tank.
Price will be determined by the valve you purchase as to the number of spools, etc.
If you only need a two spool valve, we can guide you to the right place.
The valve should have a PB port with a PB adapter.
Thanks j j can you send me a diagram I would like to buy this valve block so I can hook my 3point log splitter up thanks j j my name is Jim from oh. I have a Kubota 4310
   / Add a rear remote to a Kubota L4310 #38
Just fyi, this post is from 2015 so you may or may not get a reply. If your interested in details, I wrote up a 'how to' on adding remotes to your tractor (mine is the same, but a 4610). How I added rear remote hydraulics to my tractor
Sunflower Windmill (A53316)
Sunflower Windmill...
2008 Ford Ambulance (A47477)
2008 Ford...
Hyster H225E (A47384)
Informational Lot - Shipping (A55302)
Informational Lot...
Giyi Mini Auger (A53316)
Giyi Mini Auger...
