Good morning!!!!
   / Good morning!!!! #35,091
64F and sunny. High 96F. Winds SSE at 10 to 15 mph.
MGas, sounds like you made it to Texas just in time for a hurricane :duh: Moving's bad enough without that, but at least unpacking is inside work. Look on the bright side: Every box is like opening a Christmas present. Took me over a year to find some things after the last move, and there are still a few things I miss...
Roy, good to hear you're back on your feet. Hang in there, baby, Friday's comin! :thumbsup:
Kyle, it sounds like your mechanic was in over his head. "A man's got to know his limits", but at least it didn't cost you any more than the extra time it took to get your vehicle back. Hopefully the repair lasts, but if not, at least you know not to go back asking for anything more than a refund.
Farmer, some days it just comes down to doing what you gotta do to get it done. It may not be pretty, or go the way it should have, but as long as you get what you need, you can always catch up tomorrow. And good on ya for your ten years together. She must be a good 'un!
Drew, have a look at Rockport shoes. Well made, need no break in, even at the heels, lots of give in the sole, and good arch support. Only thing I wore back when I was on my feet all day at work. I used to love New Balance, too, as every pair fit like it was made for me. Then they took production off shore, changed all the models and lasts around, and the good fit was gone. I've also stumbled across another brand called Merrell, and after finding a pair that fit well, went back and bought two more just like 'em for when the first ones wear out. But glad you found a doctor that can help you. Life's too short to go around limping! Please don't forget your camera when you see the new boat, or the batteries and memory card :D
RS, those trunks are monsters! Sounds like you've got plenty of smaller wood on hand in case the big stuff doesn't dry enough over the summer. Wish I could tell you where to find a decent tarp. Even the so called "premium" silver ones I've tried only last a season before the sun and wind have them in shreds. And I don't know how many times I've rushed at the end of a day and skipped doing something I later took much more time to redo. Good you were able to resist temptation with that cylinder. :thumbsup:
Thanks for the support guys. This should have been a clean cut, take-what-you-brung split. No kids, we each had plenty to live on, heck, we'd never even moved in together. Instead this gold digger found an attorney that knew how to manipulate the system and milk it for every penny it was worth. But it is, after all, only money, certainly a set back, but a sad comment on both her character and that of the legal system as a whole. But that's all now in the rear view mirror. I can stay retired, won't have to move again, and can finally start focusing on the future, one day at a time.
Eric, the only thing on that judge's mind was getting someplace else. The hearing was supposed to have been four hours long, but she'd shortened it to an hour and a quarter the week before it was scheduled. Whatever her reason, it was much more important to her than anything in her courtroom. Funny thing is, I don't recall ever seeing her look me in the eye long enough to notice the paralysis. And Kyle, you're right. I suffered under two separate judges going through this, and you can bet neither will ever get a vote from me or anyone else within earshot!
Had a visit yesterday from what turned out to be a very good water softener tech. He showed up on time, went right to work replacing a few maintenance parts, checked the incoming water hardness (43 grains), and reset the controller on the softener (it was too low and wasn't regenerating often enough). There was also too much water in the brine tank, and when I couldn't get a siphon going, he showed me a trick (pay attention, Eric!). Took a garden hose and put it up to the down hill end of the siphon tube. He let the water run until we heard the bubbles stop in the brine tank, then just let the tube down. It immediately started to run, and not a hint of brine taste for either of us.
Which reminds me to ask you folks about cleaning hard water deposits from hot water tanks using acid. Saw a landlord do it once when I was a kid in college, but never found out what kind of acid he used. My tank had been in service for at least four years before the softener was installed, and every time the propane fires it bubbles and pops like it's gonna explode. I'm thinking that's because there's a layer of deposits at the bottom, but the drain and flush I tried last year didn't help. Any ideas on how to proceed with the acid, or should I just wait for the tank to start leaking and replace it?
Also got the driving lights sorted out on the old bike yesterday, and it's great knowing it's back to 100% and better than ever. That one has over 130K miles on it, has been all over the western US, Canada, and Baja, and is now ready for another 130K as soon as I am.
But before I go riding off into the sunset, today I've just got to get that new pump hooked up to the sprayer and knock down the yellow star thistle. It's now taller than I've ever seen it, and starting to flower. :shocked:
Hope everyone enjoys their day!
   / Good morning!!!! #35,092
Congrats farmer. Yeah, clean up your act and give her a little courting...paybacks are so wonderful. :D
back already from the boat. a real slam dunk. Only on the market a month, the boat is dark green alwgrip, offwhite and tan decking, very nice, has been banged up a few times and has some cracked fiberglass, likely all cosmetic but it would be fully checked out on a hull survey. He didn't do it anyway; only had the boat two years and he has put 100 hours on it.
700 hours on diesel motor, 200 on diesel gen. Probably just needs hoses after 14 years. He said he did the timing chain on the Yanmar due to age not hours, so that one big expense is done for the duration. Engine room bilges were clean, some crud on the engine due to salt water exposure. But otherwise no disasters. Poor guy is like me, back so bad he can't use the boat anymore. Well, I still can...
Tiny microwave and a single butane camping stove. The latter being undesirable to me, having gas inside the cabin but not sure I can convert to electric due to size of gen and also running a/c on a hot day. Of course, I should be cooking out on the outdoor barbecue, not inside...I'm not a comfortable sleeper while anchored out so if I overnight, it will likely be at the visitor's dock in Beaufort, Oriental, New Bern or Ocracoke. A 3600 rpm gen running in a small boat is not pleasant to my ears. At the dock, always a pleasure to turn it off.
I am getting a copy of the owner's original buyer survey to read, which is good, and then I'll make a decision. But I sure liked the boat.
   / Good morning!!!! #35,093
Drew, I don't know anything about boats, but that sure looks like a nice one. :thumbsup:
And wasn't that a tractor in one of your pics? :laughing:
   / Good morning!!!! #35,094
Looks good Drew. Auto pilot, bow thruster, radar, gps/plotter. I would think something other than a hummingbird for a depth sounder. But your not fishing. So it may be OK.
Look at a Induction burner for cooking. Uses low power and cooks fast.
   / Good morning!!!! #35,095
Yup ... the diameter of the three big logs from the last batch in the previous picture measured 37"+, 39"+, and 48"+ at the largest end ...
Yeah ... I dunno if I would say "on hand" exactly ...
I can come up with plenty of smaller wood ... but most of it would have to be cut down and bucked.
I've been cutting everything @ around 19" - 20" lengths ... I could cut those in half to 10" ... which might speed up the drying, but it might make it a PITA to handle/stack etc.
There's a large maple on the edge of leach field that needs to be taken out, has three or four trunks ... plus plenty of ash.
Just got to get the stuff cut down and get it bucked so it can start to dry and season.
If money was no object, I'd probably look at the tarps truckers that run flatbeds use ... I'd imagine those are pretty heavy and durable.
I'm at the point where I can ill afford to waste time having to redo stuff ;)
   / Good morning!!!! #35,096
Hey, I'm just happy the boat isn't named FULL MOON... ;)
induction burner and one good induction fry pan, and one good pot to boil water. All I'd need. I like to cook but maybe
not while I'm on short trips.
ok, I saw lots of tractors and combines driving around today back and forth from Edenton, some harvesting wheat and some creating a lot of dust doing something that resembled disc harrowing but looked more aggressive, like it was ripping off the surface and throwing it around.
Some were spraying, tractors on the move. some of the most fertile land in the US, the Great Dismal Swamp basin of super rich soil that seems to center at Elizabeth City. An hour South where I am and that fertile soil is now half sand. Nowhere near as good.
   / Good morning!!!!
Pretty nice day, not real hot, but really humid. Going to work in my shop for a bit, getting it organized and cleaned up.
Have a good one!
   / Good morning!!!! #35,098
Good Afternoon. 1605, sunny, 95F {105F heat index} with 49% humidity. Forecast high of 94F with 20% chance of rain today, and a low of 74F tonight.
I did my weekly trip to town today. We got our new Lowe's credit cards in the mail a couple of days ago, and they came with a 10% off coupon. I figured I might as well get as much out of that 10% as I could, so I got posts and wire for the grapevines, hoses, hose hardware { 2 and 4 way splitters, plugs, male and female ends}, spigots, pvc pipe and fittings to extend the waterline through the new part of the garden, some pepper plants, a stirrup hoe for Margie {she asked for it, really} and one of those garden wagons with the fold down wire mesh sides. Plus a few things I picked up for the BIL. I kind of spent more than I planned. The 10% savings was $40.
I want to get the pepper plants transplanted today, as well as get a few melon seeds in the ground, but when the heat index is 105. . . . . . Maybe Margie will hold the flashlight for me about 10:00 o'clock tonight:D
I almost forgot to mention me and Mamma got out early and picked about a gallon of blueberries this morning. There may be some blueberry buckle in my future.
   / Good morning!!!!
How are you dealing with the insects down there? Up here in Michigan, the skeeters are really bad today, and the black flies are there, but not in the cloud quantities that the skeeters are. My dogs go out, and come right back to the door. I worked outside a bit today, and wore jeans, long sleeve shirt, hat and a bunch of Cutter bug spray.
   / Good morning!!!! #35,100
Happy 10th Anniversary Farmer2009 & Mrs. Farmer! Hope you had a good outing.
Nice day here, high of 76F with a nice gentle breeze and not humid. Only had to use DEET once for the black flies when I started this morning and the breeze hadn't come up yet. The weather has been kind to me for rock picking. Moderate temps and not rained out for a week or two by a gusher or rainy spell.
Boat Fever. Take two aspirins and call your psychiatrist in the morning. :laughing:
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2012 Ford Edge SUV (A48082)
2012 Ford Edge SUV...
2018 Honda Civic Sport Hatchback Sedan (A48082)
2018 Honda Civic...
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
