Good morning!!!!
/ Good morning!!!! #70,201
My wife’s reflux had gotten way worse over a period of a 3-4 months, same time she noticed occasional mid chest pain radiating to her back. She insisted it was digestive, it wasn’t. She of all people, should have known to follow up on it, but we all tend to be blind of our own situation.
/ Good morning!!!! #70,202
Tuesday, driving home from work after dark, i noticed my headlights would occasionally flash brighter. Also got a check engine light, code P0142 low voltage. The other thing is my gas mileage has dropped way down.
This is my honda with 350k miles, not sure i want to spend much to investigate. Replaced alternator last yr. Not sure what is causing the lights to flash.
/ Good morning!!!! #70,203
So sad, but often so true.
Bupps, don't let it persist. I have heartburn when I eat certain foods. Bellpeppers. Chili,...I have to go easy on stuff with that.
Prayers for Rip's wife, and for cures for cancer.
I have 3 types of electric powered saws on stands in my barn right now. A tilting bandsaw, table saw, and a 7x12 metal bandsaw. Not to mention my numerous skilsaws.
I still have about five, 3/4" pneumatic impact drivers, 3 or so 1/2" models, and a few 3/8" drive sizes too. Also have about 5 pneumatic hammer/chisels that I rarely use... Yes, I need to off load some stuff.
Currently in my house, I have (working) 3 desktop computers, 2 laptops, 2 iPads (one broken), and 4 cell phones potentially hogging up bandwidth.
/ Good morning!!!! #70,204
Check your battery cables at both ends? Especially the ground.
/ Good morning!!!! #70,205
Check the cables close if they have any corrosion at all could be inside the cable is also corroded and not supplying enough amperage to run things correctly!!
/ Good morning!!!! #70,206
Buckeye, also check body grounds, that many miles bound to have corrosion in places you don't want it. Also, check connectors in wiring harness. Don't forget to check out voltage regulator after checking body grounds and battery cables, it could be faulty.
PJ listened to some of your Antonio Soler, nice. Looking forward to your you tube channel.
/ Good morning!!!! #70,207
Good evening all. 27F for the start, clear sky, light breeze. High temp was 57F, moderate wind, clear sky. WBS duty again today, general putter this morning, got some firewood split for next year this afternoon.
Happy birthday Mrs. Ed!!
Prayers for all.
/ Good morning!!!! #70,208
Thanks. Will check cables this weekend. It starts ok. Thought maybe alternator going out, it was a rebuilt. Or voltage regulator.
Drove the BAT mobile (Big Azz Truck) to work today. It guzzled some gas.
If i wasnt following someone, i probably wouldnt have noticed the lights flash occasionally. I also had the same engine code last week, but it reset itself and went off tue morning.
The battery might be getting weak, but it still starts on some pretty cold mornings.
/ Good morning!!!! #70,209
2018-02-09, 0337
18 right now...high in the mid-20's today.
Bit more snow coming in...with rain.
/ Good morning!!!! #70,210
Get a battery load tester, they tell you what the alternator is putting out. Bought one years ago and it paid for it's self many times over. Amazon has them for $29.99 so it isn't that many $$$$. Ed
/ Good morning!!!! #70,211
Good morning all, 26 now with a high of 48 and mostly cloudy. Today is the last day for a while that they don't call for rain so I am hoping we will get caght up a bit. I used to have gird but it went away when I quit taking Prolisec. Had to quit very slowly, now I get heart burn every now and then but a tums takes care of it right away.
Prayers for all that need them. Ed
/ Good morning!!!! #70,212
Accurite says 24 degrees, Wunderground says 34 degrees. I guess I have to get a new weather gizmo. Well, if there's lots of frost out there when the sun comes up, I'll know which one was right. Hard to believe I live in deep freeze hollow...
David and others in New England, safe driving. And yes David, they made me do a full heart stress test not once but twice when they doubled up my dose of Celebrex to the max. It's hard on the heart...why I don't know. I have a low pulse, ok BP, though I tend to spike, and no problems or pains. I always thought my heart was my best part. ;) The rest of me is sure falling apart. Such is life and the joys of "senior" years. We are a pretty active bunch of seniors...for those of us who qualify.
Which is what I kept in mind as I ran the Super A through the rows again yesterday. It's still clumping up too much but I think I have an answer.
My farmer neighbor has an implement he calls a "humper", ok, aka flattener, that he runs over his too tall rows which flattens the rows for planting. That's just what I need to do. So....I'm going to raise the pull behind rototiller to its highest transport position and see if that is high enough to run over the rows. The Gravely garden tractor, which has R1 rears, front end will simply bulldoze down the peaks, will sure have to give my old girl a good greasing after that. I don't need huge humps...if it had been drier the sandy soil would have flung better. As it was it tended to stick to the end of the discs and peel off in soft lumps.
My onions are talking to me. Plant us! Plant us! And the cabbages too. Beets are ready but I can't put them out until later this month, plus the electric fence has to be up and running. Beet tops are yummy, to deer and rabbits too. So if Momma rabbit wants a bite she's going to hopefully get zapped before she does. Should have three wires, low mid and high, but might run out of wire by then. Need to buy another roll; zapper is rated for 15 miles so not like I'm going to run out of juice. No electric here, could have gone solar but they are more expensive and less reliable, so I went with a 12V battery operated one. When it runs down, I just take it back to the barn, put it on the smart charger and back it goes.
Now what would be very cool is to have a small solar charger which would charge the battery, which in this case is a small sealed battery that used to be the battery in my Kubota UTV. Just about every battery I have gets a second life. Usually somewhere in the 5-7 year period I yank them out and put a new one in, using the old one to power my DC diesel tank pump, my water wagon, etc.
As the world turns, finding electric power a lot more reliable than internal combustion.
Does anyone have a recommendation for a small solar charger? Thinking Northern tools, HF if I have to.
There seems to be several grades of quality of solar chargers, and how do you tell quality from a picture?
/ Good morning!!!! #70,213
24 going to 52. Last dry day before maybe 5 with rain.
Buppies, sorry you're ailing. Get checked, but don't stress about it.
Took 8 pulls on the splitter yesterday, so my streak of 1 or 2 pulls ended, but it was cold. Got all wood cut, split, and stacked. Debating on making one last run with the tractor to the woods to cut a couple more trees...looks like the ground will thaw by 8 or 9am, so not sure I'll make it.
HVAC guy gave our system a clean bill of health yesterday on its routine inspection.
PJ, I plan to go back today and listen to your music...didn't have time yesterday.
/ Good morning!!!! #70,214
I have an Instant Pot for every meal!
Any one else in this elite club?
You beat me to it Don, I was going to suggest you had Instant Pot for every recipe.
RNG's Vanagon expert has been in the elite club for a couple of years now with instant excuse for every delay
We may soon be applying for membership with a Kettle for every tea cup.
/ Good morning!!!! #70,215
I think we are all waiting for PJ's online debut.
A sonata for TBN
Have huge respect for folks with musical and artistic talents, having almost none myself.
Good one Eric! Get all those teatpots whistling and you could have your own arrangement.
/ Good morning!!!! #70,216
6F now mid 20's for high... finally Friday. :dance1:
Mix bag weather arriving tonight into Monday AM.. snow,sleet,sun,snow,rain going to be interesting at times.
Clean snow off house roof last night couple body joints are talking this this morning.
Time for English muffin than let pickup warm before heading down to valley 8 hours.
Enjoy the day all.
/ Good morning!!!! #70,217
The wind has been blowing sleet with a fair bit of force this morning. I'm pleased to be back inside for a warm up before the mechanic returns to do a bit more work on my dumper. He will buy it if he can get it running and after spending a couple of hours yesterday I'm sure he will be trying hard again to get it going and recover the time he is investing in it. Yesterday it coughed and spluttered a couple of times, but didn't quite kick into life.
PJ A quick listen on the crappy speakers in this laptop was enough to persuade me to listen properly on a decent sound system this evening. :thumbsup:
CWB, that is good shooting from open sights. To try and get a feel for your 45-110 I put the Goex figures info into the QuickLOAD calculator.
Is 1279 fps the right sort of region for muzzle velocity ? As it goes out to 100yds that would be a difficult stability region for many bullets. Is your big chunk of lead less worried about transonic flight, or do you get many tumbling when trying to reach an optimum load ?
/ Good morning!!!! #70,218
-4 and going to a high of 12 Wind NW 5 mph.
There is nothing in the plan today that cant wait for tomorrow. Next Tuesday and onwards it is supposed to be in the mid 20's, so everything is on the 'back burner' until then.
Stay safe all, happy Friday
/ Good morning!!!! #70,219
A sonata for TBN
I think PJ's music needs the bass beat of a Popping Johnny for his TBN sonata. There is something soothing about that rhythmic pop.
Good morning 50˚ cloudy heading only to the mid 60s'. The seal kits are in the FEL cylinders and they are ready to be put back on the FEL. It only cost twice as much as the smaller bucket cylinders and the service was great. I'm glad I have only one tractor to maintain.
Eric you are in the club with a pot for every tea.
Kyle, ehh, we are still thinking about letting you join. A variety of the same type of tools is borderline. Now if you had six exact same saws for six boards you could be accepted.
/ Good morning!!!! #70,220
Poured first cup of coffee. 15° with snow this morning. Heading to 26° with more snow. Got all door thresholds sealed yesterday. No plans for the day. Radar shows we are getting a direct hit from the snow storm. But still calls for only 4". Even if it that's all we get I seem some tractor seat time in the future.
Got a call from the Cardiologist yesterday. All test came back normal. Not so good for a fellow moderator on the RV forum. Going to need open heart surgery as soon as they cure a stomach ulcer he has. Lou has diabetes. Been in what he thought was good health until his insurance company required that when he turned 60. He needed to get a baseline EKG and Stress test. He is now on medical leave from work. Curing the ulcer and preparing for surgery.
I like the idea of some of the test requirements of some insurance company's.
PJ, Classical music is not my thing anymore. Something about it wants to put me to sleep. When I was in my 20's that's what I listened to. My job required a lot of driving. Sleep is not a good thing when your driving. Switched to soft rock from the 70's and 80's. Have not gone back to Classical. Like Drew I have great respect for those that do can do it.
Buppies, hope you are feeling better soon.
Prayers for those not feeling up to par.
Good Morning All.
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
UNUSED FUTURE DM39-39" HYD DISC MULCHER (A60432)
UNUSED FUTURE...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
(3) USED 3500 LB TRAILER AXLES (A60432)
(3) USED 3500 LB...
7072CFL (A59228)
7072CFL (A59228)
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
