This tractor thing is addicting, need some guidance on implements
   / This tractor thing is addicting, need some guidance on implements #1
millsan1
Gold Member
Riegelsville, PA
Mahindra 2538 Cab, Volvo ECR40D Excavator
When I bought Britney, I did not think I would need any implements beyond the backhoe and loader.
While that may still be true, there are implements that I want.....
I have scoured TBN and the web and came up with the following as next purchases.
I just bought the Kubota 3PH kit, so I can hook up attachments.
I need to make some footers, one larger (24"x48") and many smaller (9"). The larger is for a deck footer, and yes it needs to be that big. That one I will dig with the backhoe. The others are for my future garage pole building. My land is has lots of rocks, boulders and stone.
I have done a lot of land clearing and excavating to make some level areas around the house. I also put in a 1/2 mile trail (with the help of a much larger machine). The areas I have excavated need to be leveled out to a much finer degree. The trail needs to be maintained.
I have lots of trees, both deadfall and standing timber. I want to consolidate, so a boom is in order.
For the footers, I am looking at an auger/posthole digger. I will be sinking 6x6 posts, so am thinking a 9" auger is the right tool.
For the grading/trail maintenance I am thinking box blade. 48" seems to be the magic number for the little tractors, so that is where I am heading.
Tractor Supply has all the tools I want.
Boom
CountyLine® Boom Pole - Tractor Supply Co.
Post Hole digger (plus I need to buy Auger itself)
CountyLine® Post Hole Digger - Tractor Supply Co.
Box Blade (link is to Rural King, but TS has the exact same model in stores
Tarter 4' Box Blade SC BBSCR4 by Tarter (ORANGE color) for $521.97 in Box Blades - 3 Point Blades & Box Blades - 3 Point Equipment & Accessories - Agriculture : Rural King
I believe I am going in the right direction with these choices, but feedback is welcome. I know Everything Attachments is a sponsor and makes good stuff, but TS is offering 12 month, same as cash financing, which weighs into my decision right now.
One question I do have, given my very limited knowledge, is instead of buying a boom, could I not just remove the gearbox from the auger and use the arms as a boom? I would not need to do either type of work back to back, so the hour or so making the swap would not be a factor for me. Right now it is not the $130 for the boom that is at issue, it is the fact that I have no place to put all my toys.
Thanks in advance.
   / This tractor thing is addicting, need some guidance on implements #2
I always used frame from my post hole digger as my boom. I could mount the gear box in fifteen minutes
   / This tractor thing is addicting, need some guidance on implements #3
Sounds like you are headed in the right direction. I would price Land Pride implements before going to TSC. In my opinion, they are of a better grade and offer colors that match your BX-25. The yellow color of the other brand clash too much with the Kubota orange for my liking.
   / This tractor thing is addicting, need some guidance on implements #4
My 60" land pride box blade was only $450 from my dealer....
Also you may wanna check out
Mytractortools.com
I have his quick attach mount, grapple setup, and forks. Top notch stuff and he stands behind it. I've moved a lot of trees and brush with the grapple
   / This tractor thing is addicting, need some guidance on implements #5
A 12" hole would be better, unless you are good at putting the hole in just at the right spot and stright. I'm not so I use 12" or 14" auger.
   / This tractor thing is addicting, need some guidance on implements #6
Your tractor might not be strong enough to make any difference, but any box blade that doesn't have reinforcement on the hitch pins is junk.
   / This tractor thing is addicting, need some guidance on implements #8
You have a front end loader and a backhoe... just curious as to why you'd need a boom, too? And why would you disassemble a post hole digger to act as a boom when you have a front end loader? Again, just curious. Thanks. :confused:
I have logs to move. In my mind, easiest way to do that is with a boom and tongs. And when I say logs to move, I refer to dozens of trees up to half a mile.
Carrying the logs in FEL doesn't work for me. Not sure how I would use BH for log moving.
Make sure your PHD is made for sub compacts. They do not set as high so a standard PHD will not raise high enough.
Ron
Yrp, this one is sized for a SCUT
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
