Sticking Hydrostatic Pedals MF1533
   / Sticking Hydrostatic Pedals MF1533 #21
Your have cruise control on that tractor don't you? I don't use mine very often but I could see where it would help
How many people go to the Americade? Looks like a big event.
Yes, it actually as a throttle lock for cruise. I believe we have around 55 K reregistering and another 20-30 k. Just driving through. Second generation are beginning to come, I've been going for over 25 yrs.
   / Sticking Hydrostatic Pedals MF1533 #22
I think that is all mine is too. It seems to throttle back a little when you release the pedal but I seldom use it unless my foot is getting tired
That's a lot of people in one spot. I bet it's a lot of fun too...
   / Sticking Hydrostatic Pedals MF1533 #23
I adjusted my return spring about a 1/4" shorter and it appears to be working. Sorry for the late reply but I was travelling for a bit. Peddles are a bit stiff but I'm getting used to them now.
Two different people with the same problem. hahaha, I didn't read back far enough. Yeah I would think that your 1635 shouldn't be too much different than my tractor. I was basically having the same problem as you. I was having to constantly hitting the reverse pedal. Now it comes to a stop real good and pretty quick too. Let me know if it works...
   / Sticking Hydrostatic Pedals MF1533 #24
Good to hear it worked. I don't have any trouble with mine anymore. You probably have that cruise control on it. I use it occasionally when my foot gets tired.
   / Sticking Hydrostatic Pedals MF1533 #25
Have the same issue on my 1528, I'll get under there and see if I can find the spring you guys are mentioning. Not a big deal, I'm always ready to kick the pedal in the opposite direction. But if my father-in-law gets on it he's not always as quick to reverse direction.
   / Sticking Hydrostatic Pedals MF1533 #26
You'll find it. Mine is a little hard to get at but is do able. Mine is right in the middle and is attached to the hydro pedals..
   / Sticking Hydrostatic Pedals MF1533 #27
My peddles stuck under a load but not only would keep moving but at times when digging into a pile of dirt would stall the engine unless I hit the return peddle, very hazardous when nearing the garage or lining up to attach and implement.
   / Sticking Hydrostatic Pedals MF1533 #28
My 1531 sticks until the transmission warms up then it is fine.
   / Sticking Hydrostatic Pedals MF1533 #29
You said it's doing better now though? If not you might tighten it up a little more. I had to do mine twice before I got it right.
   / Sticking Hydrostatic Pedals MF1533 #30
I have used the tractor a lot this week building a cement block retaining wall, to dig and load gravel around and it appears to returning alright now I and pleased for your tip!
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Mechanics Crane Truck (A55852)
2015 Ford F-750...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
(10) 24' CORRAL PANELS W/ (1) 8' GATE (A57192)
(10) 24' CORRAL...
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
2013 Ford Taurus Sedan (A55853)
2013 Ford Taurus...
