Just purchased SQ84T Multi-Spindle Bush Hog
   / Just purchased SQ84T Multi-Spindle Bush Hog #1
brianb88
Member
Iuka, MS
Branson 5220R/FEL
Ok, I've been on the fence about buying a bush hog(brand,size,etc). Today I went to look at a used BH6 bush hog and happened across the Squealer 84T. It was exactly what I was looking for, albeit a little more $$ than I had planned on spending. It is a well built piece of equipment
   / Just purchased SQ84T Multi-Spindle Bush Hog #2
Your tractor should turn that thing with no problem whatsoever. Congrats on the buy. I'll bet it will work out great for you.
Any pics?
So far have cut about 2 acres with it and so far so good. The grass in the background is not what I cut with this Bush Hog. It cuts clean but not that clean!
Maybe this will work
   / Just purchased SQ84T Multi-Spindle Bush Hog #5
You have good taste. I always wanted one of them. That offset cutting width would be handy for keeping the tractor further from what needs cutting or cutting under an overhang.
Did you try dropping the rear of the deck by a couple of inches? As long as it's a half inch or so higher than the front, it would cut flatter. Your PTO ujoints should last longer too.
Enjoy it!
Enjoy it!
The offset is real handy for cutting along a fence or tree line. Behind my tractor it hangs over about 15".
I have not tried to lower the rear any more than is in the picture. I cut about 9 acres over the weekend that was around 5' high sweet gum and briars (and thick) with little problem. Hadn't thought about the stress on the PTO at that angle, although in the picture shown the 3PTH is all the way down. When I'm cutting the angle isn't nearly as steep as it looks. No doubt I will experiment with different angles in the coming weeks.
2025 Swict 84in Bucket Skid Steer Attachment (A49346)
2025 Swict 84in...
500BBL WHEELED FRAC TANK (A48992)
500BBL WHEELED...
1978 LUFKIN TRAILER (A48992)
1978 LUFKIN...
2019 PETERBILT 579 (A48992)
2019 PETERBILT 579...
2023 John Deere 8R410 MFWD Tractor (A50397)
2023 John Deere...
2014 Mack CXU613 Truck, VIN # 1M1AW07Y1EM037539 (A48836)
2014 Mack CXU613...
