Semi-permanent 3pth bushing?
   / Semi-permanent 3pth bushing? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
My tractor has great extendable 3pt lift arms and a nice top link. Problem is that they are cat 2 and every implement I own is cat 1.
I really dislike using reduction bushings! They are fiddley and easily lost and worse yet can work themselves half way out of the link with some of my implements under use.
I replaced the top link with an old cat1 I had laying arroud but it was to short any would have just been a partial solution.
Has anyone tried semi-permanently afixing the reduction bushings in the 3pth?
I was thinking, after cleaning, a carefully applied thin coating of silicone calk might hold them in place. If, in the unlikely event I need cat2 pins, I could pound the bushins out.
Another option might be a couple of tack welds.
Any thoughts would be appreciated!
   / Semi-permanent 3pth bushing? #2
Tack weld and you will know where the bushings are. Simple grinder to remove if you ever need to. Tractor supply stocks a longer top link in the cat 1. That should solve the problem.
   / Semi-permanent 3pth bushing? #3
Just update the equipment pins to category 2
   / Semi-permanent 3pth bushing? #5
   / Semi-permanent 3pth bushing? #6
How about buying a category one quick-hitch?
   / Semi-permanent 3pth bushing? #7
I dont see how you are loosing the bushings. When the implement is hooked up, they cannot go anywhere. When you unhook, throw them in the tractor toolbox ready for next use.
Thanks for the tip. ��
Too many implements. Those pins aren't free.
Duplex balls! Never seen those. (not that im an expert on balls!)
Would you use a press to remove and reinstall the balls? Has anyone every done this?
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53472)
JOHN DEERE ROW...
New Land Honor 9200 LB Ratchet Binder And Chains (A53002)
New Land Honor...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
