RickeyS
Member
As mentioned you don't need a spool gun for welding Aluminum with MIG/GMAW. You can use a regular gun, I prefer the 10' lead but 12" will work. Just use a Teflon liner plus what was already mentioned in larger tip. When feeding the wire through initially you should try to keep it as straight as possible. Once its through you have less of a chance of birdnesting before the gun and at the rollers. Also take the tip off so it cannot hang up there. Another issue people commonly have is they do not have the gun fully seated at entry to the welder which causes it to birdnest.  Don't use CO2 or a mix though. Use Argon.
Tweco also came out with a machine that is more home use about 1-1/2 year ago. It was about $1K and was multi function. You may want to check it out. I ran a display using it for TIG on 12 ga stainless and it ran fine. Of course I only ran a 6" coupon so it was no real test.
