For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool?
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #1
dirt ditch
I can not find any online reference to the diameter of a 10 pound spool of wire. So am I correct in assuming that a 10 pound spool of .035 Lincoln Innershield NR-211-MP is 8 inches in diameter?
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #2
From my search it seems to be on a standard spool. What is your concern?
I just want to know the diameter of a 10 pound spool of wire.
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #4
Around 10-3/4" for the standard spool.
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #5
There are some slight variations, but typically -
4" spool, solid wire - steel, 2 lbs. Aluminum - 1 lb.
8" spool, solid wire - steel, 10-12 lbs.
12" spool - plastic spool, solid steel - 33 lbs. Steel wire frame spool, up to 44 lbs.
I don't use flux core, but it would weigh slightly less. HTH... Steve
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #6
8" is the standard size for bench top MIG welder spools. Lincoln also has 14lb ready reels of their wire but they use a different adaptor.
Thanks for the replies. A 10 lb spool is what I will get. I stumbled across Hobart's spool explanation page and found this info.
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2024 AGT JT8 2 Post Car Lift (A50121)
2024 AGT JT8 2...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
