For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool?
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #1
dirt ditch
I can not find any online reference to the diameter of a 10 pound spool of wire. So am I correct in assuming that a 10 pound spool of .035 Lincoln Innershield NR-211-MP is 8 inches in diameter?
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #2
From my search it seems to be on a standard spool. What is your concern?
I just want to know the diameter of a 10 pound spool of wire.
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #4
Around 10-3/4" for the standard spool.
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #5
There are some slight variations, but typically -
4" spool, solid wire - steel, 2 lbs. Aluminum - 1 lb.
8" spool, solid wire - steel, 10-12 lbs.
12" spool - plastic spool, solid steel - 33 lbs. Steel wire frame spool, up to 44 lbs.
I don't use flux core, but it would weigh slightly less. HTH... Steve
   / For Mig/Fluxcore welders is 10 pounds of wire on an 8" spool? #6
8" is the standard size for bench top MIG welder spools. Lincoln also has 14lb ready reels of their wire but they use a different adaptor.
Thanks for the replies. A 10 lb spool is what I will get. I stumbled across Hobart's spool explanation page and found this info.
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2006 International Bucket Truck (A55973)
2006 International...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
