Well repairs,,, OUCH!!
   / Well repairs,,, OUCH!! #21
Came home on Monday night to find I had no water pressure from my well. Did the basic troubleshooting and isolated to either a worn pump (26 years old at best guess, replaced by previous owner) or a hole in the drop pipe.
Eight phone calls later and I finally find a well company that can get to it. Long story short, 400' of 1.25" pipe (replaced severely rusted galvanized with new SCH120 PVC), new wire (original was direct burial cable with no ground), replaced pump (increased pump to 5HP), new control box (due to upsized pump), new 86 gallon tank (replaced old air over water tank with a diaphragm tank)
$6700 bucks, OUCH!!
The good news, it should last me into retirement.
What was the reasoning for going from 1.5hp to 5hp? Seems excessive.
   / Well repairs,,, OUCH!! #22
I feel your pain. I paid $5600 just last year and that was just a new pump and motor - no new pipe or cable.
   / Well repairs,,, OUCH!! #23
These prices seem high. Might be due to the well drilling rush going on now.
   / Well repairs,,, OUCH!! #24
I highly doubt they installed a "real" 5hp motor at the bottom of a 400' deep well.
I checked the motor nameplate and it said 5hp. I'm kicking myself for not looking at the numbers on the pump.
The reasoning was so the motor would last longer due to running at a fraction of it's service factor. Going from a 1.5hp to a 2.0hp or even a 3.0hp would have been sufficient, going to a 5hp was complete overkill and now creates a whole new set of problems.
   / Well repairs,,, OUCH!! #27
I sincerely doubt any well company will come out and change anything considering that is what they advised. Why would they; because some guys on a tractor forum thought they should?
   / Well repairs,,, OUCH!! #28
Let see if I got this right:
  • Well did not run out before latest problems.
  • Well is 400+ feet deep.
  • New tank is 86 gallons.
  • Pump is 7 GPM
Key questions to answer:
  1. What is the diameter of the well bore? 6 inches?
  2. What is the static water level in the well?
  3. What is he recovery rate of the well?
My well has this information on a plate attached to the well casing.
If the well bore is 6 inches in diameter, and there is 100 feet of water in the well above the pump, then there is over 140 gallons of water in well.... 50 feet of water would be 70ish gallons.
So if the pump runs 5 minutes it would only have pumped 35 gallons of water. Either the time to pump is incorrect, the GPM of the pump is higher than expected, or there is not much water in that well. 35 gallons seems like a low number if the well was working before.
Static water level vs the level of the pump along with bore size will tell you how much water is stored in the well.
7 GPM would work as long as the there was 100ish gallons of water in the well available to the pump. Since pump starts are supposed to age the pump, seems like a small GPM pump that ran longer but started less would be better.
Seems like finding how much water is available in the well bore is the key question to answer at this point.
Later,
Dan
I think Dan makes a very good point that does not appear to have been addressed.
What is the static level of the water and what is the depth of the well. Where is the pump installed in relationship between the water level and the bottom of the well? AND where was the old pump installed when it was not a problem? I think Dan said each foot of water filled pipe equals 1.4 gallons of water so how much of your total reserve in the well pipe is being used?
   / Well repairs,,, OUCH!! #29
Yeah. Doesn't make sense. Look at it this way.
- You still would have had to put out for new pump because the old one was dead.
- You still would have had to put out for new pipe because the old one was rotten.
- You still would have had to put out for new wiring because the old wire was not up to snuff.
- You still should have replaced the air tank with bladder tank.
So those are givens. You'd be out those things anyway.
Had he replaced it with same or near same size motor, you wouldn't need new breaker in panel, so the cost of the larger motor and the cost of the new breaker/control panel are added expenses.
As for it draining your well so fast.... would it have made a difference? Does the 5hp motor turn any faster than the 1.5hp motor? Nope. What makes the difference would seem to be the GPM capacity of the pump, not the power of the motor. Seems like either the pump is a much larger capacity than the old one or the old one was not pumping at its rated capacity.
As others have mentioned, what is the total depth of your well VS the water level in the well, and where is the pump hanging in that water column? The installer should have checked all that before just replacing the motor/pump.
Hello Moss, you're on the right track. I don't have any issues with most of the expense, it's just the size of the pump and motor that are causing an issue. The comments below might better explain what the real issue is.
So those are givens. You'd be out those things anyway.I agree and I have no issue with any of those.
Had he replaced it with same or near same size motor, you wouldn't need new breaker in panel, so the cost of the larger motor and the cost of the new breaker/control panel are added expenses. The cost for the new control box is insignificant to the whole price, so I didn't have an issue with getting a new control box anyway
As for it draining your well so fast.... would it have made a difference? Does the 5hp motor turn any faster than the 1.5hp motor? Nope. What makes the difference would seem to be the GPM capacity of the pump, not the power of the motor. Seems like either the pump is a much larger capacity than the old one or the old one was not pumping at its rated capacity. Based on my research, I don't think the pump is the same capacity as the original. When I look up Gould pumps, the 5hp submersibles start at 10GPM, not 7GPM (Unless this is a special order pump), so it's possible I now have a pump that's approx. 50% greater capacity. In addition, the motor is grossly oversized for the depth and pressure. The problem with the oversized motor is that I can't install a "dry pump protection device", because it doesn't have a big enough delta in the current between normal operation and a dry pump condition. Normal amperage with a fully recovered well is only 10.9 amps, during a dry pump condition, the amperage only drops to 9.5amps. All of the dry pump devices I've found look for a 25% drop in current before tripping the pump.
As others have mentioned, what is the total depth of your well VS the water level in the well, and where is the pump hanging in that water column? The installer should have checked all that before just replacing the motor/pump.Well is 425' deep, pump sits at 400', static water level is 370' so pump only has 30' of water above it. I understand it's a low capacity well. The problem is I believe I have a pump that is oversized if it is a 10gpm as I suspect. The bigger problem is that because the motor is so grossly oversized, it prevents me from adding a pump protection device.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
1992 JOHN DEERE 544E (A52472)
1992 JOHN DEERE...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2000 FORD F-650 DUMP TRUCK(INOPERABLE) (A52472)
2000 FORD F-650...
