Garage Wiring
   / Garage Wiring #11
Garage outlets are always mounted at 48" from floor. That is because gasoline fumes are heaver than air. Code Class 1 Division I requirement. Mounting that high precludes using explosion proof outlets and tools.
Ron
Let's get reasonable here. Class1 Divsion 1 classifications:
If sufficient flammable or combustible gases, vapors, or liquids are (or may be) present to produce an explosive or ignitable mixture, you have a Class I location. Examples of such locations include fuel storage areas, certain solvent storage areas, grain processing (where hexane is used), plastic extrusion where oil removal is part of the process, refineries, and paint storage areas.
Article 500 contains a general background on hazardous locations, and it describes the differences between Class I, II, and III locations plus the differences between Division 1 and Division 2 in each of the three classifications.
Article 501 contains the actual Class I, Division 1 and Division 2 installation requirements, including wiring methods, seals, and specific equipment requirements.
It's a garage, not an industrial location where flammable vapors are present. Were it Class 1 Division 1 the guy would need explosion-proof tools as well. There is NO height restriction on outlets.
   / Garage Wiring #12
When I built my small shed - 12x16 - and ran the wiring my only concern was - higher or lower than 36 inches. "Normal" shelf/counter top height is 36 inches. I went over 36" so my outlets will be above any future counter tops. I then insulated and covered the walls with 3/8 plywood. I REALLY do hate sheetrock. The shed is single purpose - its for my motorcycle & all associated M/C paraphernalia.
   / Garage Wiring
Yes I normally put the outlets higher also in a garage or shed so that wasn't a big deal. I will wire it so I can insulate and cover the walls during the winter. I like wood on the walls so it is easy to hang things not having to find the studs.
   / Garage Wiring #14
Residential garages do not fall under NEC classisied codes, so per say there is no height restrictions. No arc faults are required. But ALL OUTLETS incl garage door operator and any freezers, etc are to be gfci protected.
Mechanical codes require water heater heights, not nec codes.
My company has always placed garage outlets at 42" high (measured to bottom of box) for one reason only.... To allow for work benches.
   / Garage Wiring
Can you explain the water heater height I may put a small bathroom in?? I read GCFI not required on any outlet that is not accessible such as outlets behind freezers and large things that are left plugged in and not moved??
   / Garage Wiring #16
for the last 2 code changes, ie last 6years, EVERYTHING in a garage reguardless to height or use is to be gfci. The water heater isshu has to do with them being on a 18" pedistal. Here in idaho building inspectors (not elect inspector) requires. When i work in wash state, same regs are enforced.
   / Garage Wiring
Perfect thank you good info!!
   / Garage Wiring #18
You got good info by the end of the thread up to now (no you are not in an explosion proof environment, but you get that now...:rolleyes:). One thing I will add for outlet heights is my own experience. If you do a lot of woodworking and have sheet goods around (plywood, melamine, OSB, etc) it pays to make sure the BOTTOM of your outlets are about 49" above the floor or a bit more. That way when you lean plywood against the wall, the outlets are still above it and you don't have to worry about damaging cords plugged in. Just a little experience for you... Good luck with your project.
   / Garage Wiring #19
What a great tip.
   / Garage Wiring
Thanks for all the good info guys!! Just playing the waiting game now for the contractor to get to me on his schedule. :(
197711 (A51244)
197711 (A51244)
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2011 Liebherr L586 Wheel Loader (A55218)
2011 Liebherr L586...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
