extending my new hydraulic cyllinder. question
   / extending my new hydraulic cyllinder. question #1
markturik
bailey nc
kubota 2910
i have a home made grapple question. i have a new 2" diameter by 8" push hydraulic cylinder. i want to measure the opening distance of my grapple before i install the hydraulic lines. question:? can i extend the hydraulic ram cylinder with out the hydraulic lines attatched? in other words, if i open the in/out ports, can i pull the cylinder out with out damage? thank you for any thoughts and help. mark
   / extending my new hydraulic cyllinder. question #2
You won't damage it, but it will probably pull out harder than you think
   / extending my new hydraulic cyllinder. question #3
That is why I said in his other post oil will probably shoot out several feet. When they finally move they tend to move fast.
what is the best way to pull out the ram? and thank you for your time helping me! mark
   / extending my new hydraulic cyllinder. question #5
You can probably pull it by hand. It would be easier to just hook it up and use the oil to push it out.
   / extending my new hydraulic cyllinder. question #6
There should be specs on the cylinder, no?
Or, hook it up as already suggested.
   / extending my new hydraulic cyllinder. question #7
Open both ports and slowly blow compressed air into the extend port.
   / extending my new hydraulic cyllinder. question #9
Better be extremely cautious with air. It wouldn't be my first choice on how to do it
   / extending my new hydraulic cyllinder. question #10
tie one end to something that won't move. Put a bar through the other end to use a a handle and pull like a bugger.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
