extending my new hydraulic cyllinder. question
   / extending my new hydraulic cyllinder. question #11
tie one end to something that won't move. Put a bar through the other end to use a a handle and pull like a bugger.
Yup, turn it a bit too as you try to pull it out, onc it starts to move it should move fairley easy.
Be real careful with air, not only can you do some damage to yourself it can also knock the end of the cylinder off when it bottoms out on the cap....Mike
hi and thank everyone for helping me with my grapple project. i spent 2 days on my project. i need to run the hydraulic lines and clean up the welds and then make it orange. guess what kind of tractor i have...... the help with the hydrualic cylinder was in valuable to the grapple project. PHOTO_20150628_143152.jpgPHOTO_20150628_143558.jpg
   / extending my new hydraulic cyllinder. question #13
hi and thank everyone for helping me with my grapple project. i spent 2 days on my project. i need to run the hydraulic lines and clean up the welds and then make it orange. guess what kind of tractor i have...... the help with the hydrualic cylinder was in valuable to the grapple project. View attachment 431288View attachment 431290
Be very careful as you begin using this. It will start to bend and youll be able to see where to strategically place bracing to tufen it up. Where possible use brace elements in tension.
,,,Youre going to need some large compressive and torsional elements tho. Welding more metal to form box sections where needed is an option with the strap metal frame you have.
larry
hi larry,,
thank you for the bracing advise. i almost always over due it when it comes to support. if a little is good a lot must be better. i have studied my design and do have some ideas about additional bracing at the heavier pull / push points. thanks for the advise i will take it to heart. mark
Hyster H225E (A47384)
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
