Transporting a bush hog
   / Transporting a bush hog
Thanks for the info. Still working on the solution.
   / Transporting a bush hog #12
Probably get a rollback for about $125. Not that much if it's a one time thing.
I agree a rollback makes sense, still working on how to get it on and off without tearing up the bush hog
   / Transporting a bush hog #14
Boards - 2x4 runners
   / Transporting a bush hog #15
It's a brush hog, not a corvette. Maybe your over thinking this deal? Seems it should be pretty difficult to damage.
   / Transporting a bush hog #16
If there is no tractor where its going, how is it gonna get used?
I assume at some point there will be a tractor there. Is it possible to wait til then to move the cutter.
   / Transporting a bush hog #17
Put a couple of 4x4 runners under it and then jack up one side and use wooden blocks or cinder blocks to block it up. Repeat on the other side. When it is high enough, back the trailer under it and lower it down to the deck with the jack, one side at a time. Repeat the same thing at the destination in reverse. Might take a half hour or so to load and unload. Make sure you don't have any appendages under it while jacking or lowering.
If you have a FEL to load it on the trailer, then you only have to do that at the destination.
There is a tractor there, just no FEL.
   / Transporting a bush hog #19
Hook it to your truck and pull it, but stay at 20 MPH or less.
Back it on rollback with tractor and leave at very rear. Hook to tractor to unload.
   / Transporting a bush hog #20
Ironpen, I just realized you are in Montgomery. Where are you moving it to and from?
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
