Brush hog
   / Brush hog #1
Massey481
Oklahoma
Massey 481
Have a 6' brush hog. It doesn't say the name on it. I can't find a gear box to fit it. Bought one but the splines didn't match. Not sure where to look to fix it. Any ideas?
   / Brush hog #2
Omni Gear may make one that will work.
Rotary Cutter Drive | OmniGear
If the standard shaft doesn't fit, find the right size gearbox, then contact them about custom shafts as mentioned in the downloadable brochure.
Bruce
   / Brush hog
   / Brush hog #5
I always thought if it had a stump jumper it was a brush hog. If it dont have one its a stalk cutter.
   / Brush hog #6
Not necessarily. Brush hog is just a generic name for a rotary cutter, some of which have a stump jumper (i.e., a blade PAN) and some of which have a blade BAR.
   / Brush hog #7
Can't read the lettering on the sides, but it has "Cutter" there.
The three point hookup is unique, someone will recognize it.
attachment.php
   / Brush hog #8
Not really. Bush Hog is a brand name of a manufacturer of implements, the most well known of which is a rotary cutter.
Terry
   / Brush hog #9
Terry
I know that. But "brush hog" (lower case and with an "r" to make it "brush" instead of "bush") is just a generic term that people use for almost any rotary cutter regardless of brand name. I know that it is a great source of irritation to the Bush Hog folks, and causes even more consternation among their lawyers, but it is fairly common parlance these days.
   / Brush hog #10
Big Bee Rotary Cutter is your answer. I don't know much about them other than this is their heavy duty version.
The correct term for all of these mowers regardless of brand name is "rotary cutter" or "rotary mower". The term coined "brush hog" is because people use them in literally the brush. Bush Hog is a brand and people commonly call their King Kutter a bush hog. Not all mowers are created equal and I believe Bush Hog is the top of the line. Followed by the likes of Woods and Hardee. Countyline (tractor supply), King Kutter, Howse, and the likes are just economy mowers not meant to take a beating.
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
MANTIS 155B LOT NUMBER 230 (A53084)
MANTIS 155B LOT...
2021 ARISING INDUSTRIES, INC 24 T/A ENCLOSED TRAILER (A52472)
2021 ARISING...
