Brush hog
/ Brush hog #1
Massey481
Oklahoma
Massey 481
Have a 6' brush hog. It doesn't say the name on it. I can't find a gear box to fit it. Bought one but the splines didn't match. Not sure where to look to fix it. Any ideas?
/ Brush hog #2
Omni Gear may make one that will work.
Rotary Cutter Drive | OmniGear
If the standard shaft doesn't fit, find the right size gearbox, then contact them about custom shafts as mentioned in the downloadable brochure.
Bruce
/ Brush hog
/ Brush hog #5
I always thought if it had a stump jumper it was a brush hog. If it dont have one its a stalk cutter.
/ Brush hog #6
Not necessarily. Brush hog is just a generic name for a rotary cutter, some of which have a stump jumper (i.e., a blade PAN) and some of which have a blade BAR.
/ Brush hog #7
Can't read the lettering on the sides, but it has "Cutter" there.
The three point hookup is unique, someone will recognize it.
attachment.php
/ Brush hog #8
Not really. Bush Hog is a brand name of a manufacturer of implements, the most well known of which is a rotary cutter.
Terry
/ Brush hog #9
Terry
I know that. But "brush hog" (lower case and with an "r" to make it "brush" instead of "bush") is just a generic term that people use for almost any rotary cutter regardless of brand name. I know that it is a great source of irritation to the Bush Hog folks, and causes even more consternation among their lawyers, but it is fairly common parlance these days.
/ Brush hog #10
Big Bee Rotary Cutter is your answer. I don't know much about them other than this is their heavy duty version.
The correct term for all of these mowers regardless of brand name is "rotary cutter" or "rotary mower". The term coined "brush hog" is because people use them in literally the brush. Bush Hog is a brand and people commonly call their King Kutter a bush hog. Not all mowers are created equal and I believe Bush Hog is the top of the line. Followed by the likes of Woods and Hardee. Countyline (tractor supply), King Kutter, Howse, and the likes are just economy mowers not meant to take a beating.
/ Brush hog #11
It's a World Agritech Corp (International Machine) rotary cutter, appears to be a Model 600H. The gearbox should be a ITG brand 75hp gearbox, 6 spline input and 15 spline output. part number 01-114. If you still need a gearbox I have them available!
/ Brush hog #12
Yep, pictures online are scarce, but here are two.
Here is a dealer in Tahlequah if you are in the eastern part of the state: 302 Found
attachment.php
attachment.php
2006 Freightliner Auger Truck (A63118)
2006 Freightliner...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
