Man I hope some of you clutch guys can help me
   / Man I hope some of you clutch guys can help me #1
Kosmo
NE Pa
Ford/NH 1715
Hi all,
So I'm putting the clutch job on my 1715 compact back together, and I go to install the thrust bearing and I can't remember for sure which face of the bearing goes toward the clutch. The diagram in the manual suggests that my memory is wrong. Does anyone know if the smooth face of the bearing faces the clutch? I could have sworn that this was the case until I looked at that diagram in the manual.
   / Man I hope some of you clutch guys can help me #2
There should be a flat face that compresses the fingers on the pressure plate. If you hold from the inside (as if mounted) then look at the bearing and how it spins, should be fairly clear which area contacts the fingers.
Yeah, That flat face was the way I thought it should be but the diagram in the manual confused me. Thanks a bunch!!
Jones, just being **** and checking with a picture.
The new bearing is installed to the hub correctly as I see it on the right. The old bearing on the left shows the backside. Is this correct? Thanks for your input again. Also, do you know if the hub gets any kind of grease where it slides onto the hub support shaft. It appears that there was old grease on that shaft but I would expect, during assembly it, should be very minimal due to proximity to the clutch. NH manual says nothing about lubrication during assembly. Thanks again.
   / Man I hope some of you clutch guys can help me #5
The repair manual that I have states "Lightly lubricate the hub splines of the transmission input shaft using a high temperature lubricant." The bearing install looks correct.
Thanks billybob!!
   / Man I hope some of you clutch guys can help me #7
Yes that is mounted correct.
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
