EddieWalker
Epic Contributor
You are not going very far and you are only planning on one source to use the water from. I would stick with the 3/4 inch size since you will never notice any difference by going up in size for that length of a run. I doubt you would notice if you did the whole run in half inch, but that would limit you if you ever wanted to add onto that line, so stick with the 3/4 inch pipe. If you can find a single roll of 3/4 in PEX, go with that. If you go with shorter lengths, you will create bottle necks in the line because the connections fit inside the pipe and they are considerably smaller inside diameter. PEX is best when it is run without any breaks in the line. I know you can get 300 foot lengths, but it might take awhile to order it and you might not want to pay for it. I've done longer runs with 20 foot lengths of PVC. Remember , purple primer and heavy duty clear cement. Nothing else works anywhere as well!!!
As for your spicket, I only use copper from my underground connection to the supply pipe to my threaded male fitting at the end. I don't trust anything else, and once done, you never have to worry about it.
Eddie
Eddie
