Water volume and pressure question
   / Water volume and pressure question #21
Avoid PVC in general. A continuous run of coil pipe flows best and will never give trouble.
I agree. PVC is an old technology that is past its time. PEX is so much better, withstands freezing, is so very flexible, and will last and last and not become brittle over time.
   / Water volume and pressure question #22
One advantage to PVC is gophers don't eat it... they love to munch on the black poly pipe... and probably PEX.
   / Water volume and pressure question #23
Any time you have tubing that has to have a fitting stuck into it is going to slow down the flow. You would have to run 1" PEX to get a 3/4" flow thru it.
For my rock filled soil, I will stick to schedule 40 PVC and use the blue glue. It dries faster than the clear, a little water doesn't affect the joint either. It is especially effective when tying into existing lines that may tend to drip a bit of water when joining. I always hated trying to keep the kinks, dips and dives out of rolled tubing when laying it in a ditch.
   / Water volume and pressure question #24
Make sure you have schedule 40. It does not come with belled ends, normally. The belled stuff is schedule 10 and schedule 20. It works fine for irrigation systems but the PSI rating is not for water service and it fractures real easy.
Ron
Not sure where you are getting your data, but 20 foot sticks of schedule 40 PVC is very common with the belled ends. I've installed thousands of feet of it and I've never heard of it not having the belled end to slide them together.
Schedule 40 PVC is the best choice for this application in my opinion, and if installed properly, will be there forever. Purple primer and heavy duty clear cement. Nothing else is as good for jointing them together. You don't actually glue them together, the purple primer actually softens the PVC and then the cement melts them together. Once cured, the joint is stronger then the pipe itself.
If he was going with larger pipe, like 2 inch or more, then the best choice would be pipe with gaskets that slide together.
I like PEX and would use it if the price was right for a continuous run. Black Poly is a low cost pipe that tends to fail more often then any other type of pipe in the ground. In my area, it's no longer allowed do to all the problems the water districts have had with it breaking. Remember, when the ground is wet and it freezes, it moves. Black Poly breaks after a few years and is a constant problem all winter long in areas it's been used.
Eddie
   / Water volume and pressure question #25
I ran 3/4" poly for 1100 ft to my garden down below and a "pumping station" for a 12v pump. I looked up the friction drop for a normal 1 to 5 gpm flow rate. It's insignificant.
3/4" is fine. I was a chemical engineer for 31 years. We did dozens of these type of calculations all the time.
Ralph
   / Water volume and pressure question #26
Eddie
That's interesting... does your ground typically have sharp rocks? Black poly is used a lot here for sprinklers... one advantage is if there is some water in it during the winter it will expand instead of breaking like PVC will.
   / Water volume and pressure question #27
U
A point restriction is different than a full length restriction.
   / Water volume and pressure question #28
One possibility is to add a pressure tank to the end of the line when you need higher flow for a bit, then it does it's thing and keep flow going for an extra few gallons.
M
   / Water volume and pressure question #29
Yaay Egon! :thumbsup:
   / Water volume and pressure question #30
My choice would be shc. 40 PVC ( not the farmer one but the heavy one) or municipal tubing and mular (?) couplers the second choice the fittings are expensive but I have never had one fail and they can be easily loosened after many yrs. in the ground they are compression fittings and no restriction. If you plan on tying in more water lines to the run 1" would be a good choice for the main line other wise 3/4" will do .
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2012 VOLVO BL70B BACKHOE LOADER (A51406)
2012 VOLVO BL70B...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2013 John Deere 824K Wheel Loader (A55218)
2013 John Deere...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
