starter turning backwards
   / starter turning backwards #1
tammyp
sst framcisville,la
2516 mahindra
I have a 2516 Mahindra. Tried to start it nothing. After a further look I discovered the starter is turning backwards. Any suggestions as to why and how to correct?
   / starter turning backwards #2
Need more info such as, was it running fine before and then suddenly won't start? How do you know it is running backwards?
Yes it had been running no problem. No problems. Hadn't replaced anything such as battery. Took starter off and two different friends helped me check it to discover it was spinning backwards.
It spins but wouldn't engage so that's when we discovered it was spinning backwards
   / starter turning backwards #7
Could you post a picture of the wiring to the starter? Also, is anything else electrical on your tractor not working?
   / starter turning backwards #8
Have your two friends return and swith positions so that they hook the wiring back up correctly. Red is not ground, its the other red meat er, ground. Otherwise think positively, now you have a lot more reverse gears !!!
   / starter turning backwards #9
Im guessing there has been a perceptual error on rotation. The lack of engagement is likely a mechanical issue in the starter solenoid.
   / starter turning backwards #10
when you engage with power does the drive spin out from housing or stay in place and just spins if all it does is spin you are probably using the field post which will only allow gear to spin not engage or spin out is this the case
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
2009 Wilson Hopper Bottom (A59814)
2009 Wilson Hopper...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56438)
Magnolia Trailer...
10' CONTAINER (A52706)
Ratchet Straps (A59230)
Ratchet Straps...
