starter turning backwards
   / starter turning backwards #12
Benxisdrive of starter faulty and slipping !
THIS,
or just stuck on the shaft , try tapping in in an outward direction and see if it will loosen up.
   / starter turning backwards #14
Wheres the OP?
   / starter turning backwards #15
New battery has post backwards to original ones, battery connected backwards causing starter to run backwards. Hope you haven't damaged the charging system.
Walt Conner
   / starter turning backwards #16
Walt Conner
Did you make it to the 4th post? :
Yes it had been running no problem. No problems. Hadn't replaced anything such as battery. Took starter off and two different friends helped me check it to discover it was spinning backwards.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
