Running 500 feet of underground wire.
   / Running 500 feet of underground wire. #51
#10 wire won't be nearly big enough to get a 15 amp circuit at that distance.
wire size calculator
THANK YOU for this! I'm going to have to run 1300 feet and if I've entered correctly, I need 500 MCM copper or 700 MC aluminum....now to see where I can purchase it INEXPENSIVELY!
   / Running 500 feet of underground wire. #52
What are you running?? That's a lot of amps!
   / Running 500 feet of underground wire. #53
For that long of a run, look at getting a pair of transformers to step the voltage up (to from 120v to 480v), then back down to 120v.
They will probably be a couple of hundred apiece, but for that long of a run they might be cheaper than heavier wire.
Aaron Z
   / Running 500 feet of underground wire. #55
Aaron Z
It's Canada, we don't bother with that wimpy 480V We use 600V.
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F450...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JOHN DEERE LOT NUMBER 124 (A53084)
JOHN DEERE LOT...
