Plate thickness for pintle hitch
   / Plate thickness for pintle hitch #11
Okay. I'm confused. (what's new :D). I assumed the OP said Harbor Freight 'tongue in cheek'??
Terry
   / Plate thickness for pintle hitch #12
I did this job on a peterbuilt otr truck from canada that was converted to a dump truck. We added a hitch to haul equipment for AJAX paving company and 3/4" plate worked great.
we hauled all kinds of paving equipment. dozers, loaders, rollers, broom trucks, pavers, graders and more.
just be carefull of any harbor freight welders. you have to mod them to get decent beads. and even then the penetration sucks.
I would recommend just going to lowes or home depot and getting a good name brand arc welder. you dont want to see your trailer rolling up next to you while you are going down the road do you???
think about that... your putting your life and the people around you lives at risk.
dont use a wire feed/mig welder for this job. they do not have the penetration you need for this job.
you want to look into a 220v AC arc welder and 60-10 or 60 -11 rods. Dont use 70-18 rods and dont use 70-24 rods even though they are easier to weld with.
wire feed welders work great on trucks when you are welding on mud flap brackets or light brackets and little stuff like that.
I am saying this because I do have experience. I am a welder. I went to school for welding at tampa bay vo tech in tampa florida for 4 years.
And I am not trying to be a smart *** about it... I just know what I am talking about. I dont want to see anyone get hurt because of a crappy harbor freight welder.
   / Plate thickness for pintle hitch #13
Rut roe, I welded these down with a wire feed.:D
   / Plate thickness for pintle hitch #14
with all due respect, I am sure you know what you are doing and you know how to set up a machine and multipass a beveled vertical t joint while laying on your back. and then have it xrayed... I get it... you know what YOU are doing with a wire feed.
BUT we are talking about a first time welder doing load bearing work with a harbor freight wire feed.
maybe I am right, maybe I am wrong. Weigh the facts here and you make up your own mind.
   / Plate thickness for pintle hitch #17
Pretty sure this post contains elements of fiction using newbies & their Harbor freight purchases for entertainment.
   / Plate thickness for pintle hitch #18
with all due respect, I am sure you know what you are doing and you know how to set up a machine and multipass a beved vertical t joint....
I haven't been welding very long. But I did stay at a Holiday Inn once! ;)
   / Plate thickness for pintle hitch #19
Your broken weld might be more a fault of using the wrong wire or welding on a heat treated frame without the using the proper procedure rather than from welding with a wire feeder. What ever process is used, a 10 ton hitch on a truck should not even be considered by a beginner welder. Some jobs just require experience and know how and a heavy duty hitch is one of those things. There are flux-cored and solid wires to cross to most stick electrodes. The welders sold at Home Depot even though they say Lincoln on them aren't a whole lot better than HF welders. If you want a good welder the box stores aren't the place to go.
   / Plate thickness for pintle hitch #20
I've said it before, and I'll say it again. When it comes to wire feed welding, there is no substitute for horse power! :thumbsup:
UNUSED FUTURE XKH39 39" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE...
2020 Chevrolet Tahoe SUV (A55853)
2020 Chevrolet...
UNUSED FUTURE MINI EXCAVATOR (3) PC AUGER SET (A57193)
UNUSED FUTURE MINI...
2006 International 9400i (A55302)
2006 International...
ATTENTION PLEASE READ (A56469)
ATTENTION PLEASE...
2006 CATERPILLAR D4G LGP CRAWLER DOZER (A52707)
2006 CATERPILLAR...
