Texas Now Enforcing Trailer Inspections
   / Texas Now Enforcing Trailer Inspections #21
Buddy hauling in a 1 ton truck + skidsteer got ticketed for no CDL.... This was earlier this year in Granbury.
I believe it because he was probably over 26k combined GVWR. A lot of the newer dually's are rated above 12,000lb. Some are 12.5k for example which I think is stupid because 14k trailers are very common. Hook a F-350 with a 12.5k GVWR to a 14k trailer and you are over 26k and might as well be in a 18 wheeler in the eyes of the law.
   / Texas Now Enforcing Trailer Inspections #22
If he gets one more ticket for no CDL, he will never be able to obtain a CDL. This is exactly why I got a Class A CDL to pull my 22,500 lbs. farm tagged gooseneck.........all the grey areas.
   / Texas Now Enforcing Trailer Inspections #23
Probably not a bad idea but if it is truly farm use and not a grey area you are good to I think 48k pounds with no CDL. In a truck hauling grain from the field to the elevator no worries but a flatbed hauling a piece of equipment they could challenge you on the farm use.
For those that don't know a CDL is a pain in the butt. There is a LOT more to it than just having the license.
Your truck and trailer need commercial inspections not the regular safety inspection.
You need reflective triangles and a fire extinguisher in the truck.
You need a medical card.
You need commercial auto insurance.
You need a DOT number which comes with audits.
You need UCR registration.
You need operating authority.
You need to be part of a random drug testing pool.
Pretty much all this stuff has annual costs.
   / Texas Now Enforcing Trailer Inspections #24
Go here and go through the flow chart and get it straight from the horses mouth. https://www.dps.texas.gov/cve/cdlmain.htm
Can't trust Texas. :)
   / Texas Now Enforcing Trailer Inspections #25
My RED Mahindra has a RED backhoe on it most of the time. I do a lot of bartering. It could fall into a grey area. Correct, the limit is 48,000 pounds.
hugs, Brandi
   / Texas Now Enforcing Trailer Inspections #26
Yep. My '05 flatbed is rated at 11,500 so I'm fine with a 14k trailer. If I ever decide to go heavier....might as well go big.
   / Texas Now Enforcing Trailer Inspections #27
My inspection guy mentioned that the state has asked them to verify that the vin on the registration matches the one on the trailer. That hasn't been an easy task since a lot of the tags are so faded.
   / Texas Now Enforcing Trailer Inspections #29
I go straight to the webpage. I do not get that message. Maybe it is on your end of the computer?
hugs, Brandi
Firefox doesn't trust Texas, but Safari does.
Bruce
   / Texas Now Enforcing Trailer Inspections #30
Bruce
Bruce,
I don't understand that. I'm using Firefox.
hugs, Brandi
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
UNUSED WOLVERINE DUM-26-73W 73" HYD DRUM MULCHER (A57193)
UNUSED WOLVERINE...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
