sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,667
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
When you strap or chain down a tractor for towing, is it OK to just hook the end of the straps into a clevis or hook ? this would mean that the strap tension keeps the end of the hook secured? Or do you wrap the end of the strap inside or around something first and then hook it so that even a slight loosening of the strap keeps it in place?
I ask because I normally secure the front of a trailered tractor with two straps--one on each side. With my front end weights on, I can't hook normally and am considering using a 1/2" clevis in the weight bracket and hooking my strap into that--one on each side of the front.
Assume all the obvious here that four straps or chains are used and correct methods are used.
I would post a picture but for some reason am still unable.
