3 point hitch won't go down
   / 3 point hitch won't go down #1
Crtsmcdonald
Valley view
New holland tn75a
I own a 2005 new holland tn75a ,the 3 point hitch will not go down with the controll lever.it will go down when you move the little control lever in the back of the tractor. But if the tractor is running as soon as you release it it will raise all the way back up.
   / 3 point hitch won't go down #2
There is a knob somewhere on the tractor that controls the rate the 3pt drops at. Make sure the knob is open. On my tractor it is located between your legs a few inches off the floor board.,
   / 3 point hitch won't go down #3
adding to above...
the knob is normally located between your legs just below the seat. it controls how fast 3pt hitch raises / lowers. question comes up more times than i want to count and normally resolves issue.
   / 3 point hitch won't go down #4
adding to above...
All rate of drop screws on 3 pt hitches I've seen only control decent(lowering speed) but not raising speed
   / 3 point hitch won't go down #5
thx for correcting me :)
   / 3 point hitch won't go down #6
Did you drop a viagra pill in the tank like the fiat commercial?
   / 3 point hitch won't go down #7
This happen to my TN 55 when it was still on warranty, the dealer said that some linkage got disconnected inside the case. Happen when raising a box blade and the dirt pile forcing it up higher that the lift. Good luck on a low cost fix. The TN 55 does not have a rate knob for the 3pt.
Thanks for the info, I am afraid that's maybe what has happened , because the lever moves a little easier than it use to.
   / 3 point hitch won't go down #9
Where is the rate knob on a Branson 4720?
   / 3 point hitch won't go down #10
Right in the middle of your legs :)
You'll see one higher, that's for the seat suspension. Looks further down, there is a knob to adjust down speed for the 3 pt.
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
City of Lakeland (A51691)
City of Lakeland...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
