Hay Spears
   / Hay Spears #11
We use round bales and like the fellas said you need at least 2 spears, although one of them can be short as all the 2nd one does is stop the bale from rotating. I bought one at TSC but it was poor quality steel and bent. Make sure you get a better quality one than the "discount" brands. I have a few, got them at auction sales quite cheaply.
   / Hay Spears #12
2 spears, both titian.
Front are pallet forks with spear + side stabelizers
Rear is receiver hitch/gooseneck mover with hay spear + side stabelizers.
Both attachments are multi use.
   / Hay Spears #13
Maybe look at a haying grapple. Yours looks to be more of a brush grapple. You can get them with enough reach to grab both sides of the bale.
With a backhoe I'd only get the front spear. Either a double spear design or a 3 prong design. With the 3 prong design the vertical distance from the long spear to the short ones is important. It its really close they don't stabilize the bales and the will rotate. To far apart and when you spear the center the short prongs are on the ground. Still same problem. I don't like the county line ones. I think they're too close.
   / Hay Spears #14
...... Since we are down to 2 horses it's easy to feed square bales now and cost less.....
Wondering how you calculate it as costing less? You mean they eat less or waste less, 'cause out west round bails are less expensive than small square bails.
One of the main justifications to get an AG tractor was to swap to large bails rather than use small square bails. Got tired of loading/unloading/stacking/unstacking/feeding 12 tons a year by myself. Lots rather use hydraulics to move the tonnage. On the downside, I figure my equine will eat more now and get fat.
   / Hay Spears #15
Eddie
I use my front QA pallet forks instead of a spear...works for me and I get double duty out of the forks
   / Hay Spears #16
I like a 4 ft spear on the FEL, enables me to unload two 5 ft bales from the same side of trailer.
   / Hay Spears #17
Eddie
Actually this is a great idea. My pal does this too.
   / Hay Spears
I have pallet forks, but didn't think they would work. Do they slide into the hay just like the spear does?
   / Hay Spears #19
Wirh pallet forks i'd pick them up from the bottom.
   / Hay Spears #20
widen them and go under the sides of the bales ... sorta craddle the bale.
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
2001 Ford F150 (A50121)
2001 Ford F150...
