Good morning!!!!
   / Good morning!!!! #36,771
good evening. Just wrote a long description about my microwave dying, and then it all disappeared from this box...
so to repeat myself, my 30 yr old microwave died today. has the burnt electrical smell. took the cover off, nothing looks burnt. fuse is good. complete electrical schematic and troubleshooting guide inside the cover. will probably attempt to repair. plugged it in, display working, can use the clock. enter cook time, nothing happens. too late tonight to do any more.
   / Good morning!!!! #36,772
I have 2 fuel oil tanks I need to remove from my basement, since I now have geothermal. thought about putting one in the barn for diesel fuel, but I really don't use that much diesel. Guess I should try to sell them. One is not even piped in. When I added the garage onto my house, I built a small basement off the garage where it connects to the house. I bought a new oil tank and installed it there, then when my existing tank in the basement was empty, I switched the line to the new tank. i then moved the old tank beside the new tank, but never even hooked it up. Now I don't need either of them.
I have no end of unfinished projects...
   / Good morning!!!! #36,773
2015-08-14, 0323
59 right now and warming up to 84 today. Looks like we have a heat wave rolling in for the next week or so...
   / Good morning!!!! #36,774
We have rain. Lots of it. Not the frivolous, fine drops that wet hardly anything, nor the lazy kind that wets the surface without bothering to penetrate the ground, nor the vicious quick heavy downpour that tries it's upmost to do damage. This is good wholesome, well behaved steady rain that has been falling all night and hopefully for a few hours to come. Just what we needed. :dance1:
   / Good morning!!!! #36,775
67 going up to 86 today in fair weather. Worked outside most of yesterday afternoon, sprayed all the trees in the orchard and most of the azalea bushes in the front of the house, which had been covered in some grunge. I had sprayed those bushes about two weeks ago and found my custom orchard mix did just fine on the bushes; most of the grunge is gone and new growth is coming out without it. Whatever is in the orchard spray is clearly multipurpose, and is likely on the weak side I think of alternative chemicals to use. Everything I've sprayed with it looks better. Fruit trees have been heavily munched by some bug, lots of leaf loss. I really soaked those trees in spray this time, eat that bugs and go choke on it. Bugs ate 99% of the leaves off a beautiful pin oak tree I had planted last Fall. Healthy, great leaf growth, then chomped, like a deer going through your garden.
Good news is I got my orchard sprayer back yesterday, with a new carb put on under warranty. Pretty sad when you have to replace the carb on a brand new Honda...what is the proverbial world coming to?.... I also went to the JD dealer and got my Yanmar air filters. 20 bucks apiece for the inners and outers. Luckily I have confirmed the Donaldson style filter here is generic and I don't have to buy JD replacements. The inner filter after 122 hours looked brand new; didn't need replacing at all. Outer filter pretty gray, time for it, but that thin tubular inner filter looks/feels almost opaque; how air gets through it eluded me, but then many things do...
My biggest challenge is lifting full five gallon tanks over my shoulders and up on top of the Kubota hood. I can still do it, but it's really hard on me holding it there while I'm fueling. Every time I put diesel in there I dream of a nice nozzle and pump...couple thousand dollars cost in buying the tank, the pump, the fuel filters, and then for sure filling the darned thing. Since I use a lot more fuel in the diesel garden tractor and that's of course easy to fuel, I've been procrastinating. Maybe since I'm not building a big garage back there I'll treat myself to a fuel tank. have a place to call, will ask about zoning/permits/pollution requirements. Whatever I install, if I install, will be to code since I don't want any issues when I go to sell this place someday. this isn't Kalifornia, so I'm not sure about double tanks, retention tanks, etc. If I buy a brand new single wall tank, it sure had better not leak in my lifetime...
I've seen a lot of those diesel tanks with pumps sitting out in the elements uncovered. I might try to put a little roof over it, or if I do build a concrete pad and shed roof back there, which the contractor is coming late today to talk to me about, I might set the tank in the corner on the proposed concrete and where I can get to it from several directions. I spent some time maneuvering the tractor with loader and mower back behind the barn making sure my stakes allowed enough turning room. About sixty feet behind the barn is the main six foot deep ditch. Need to stay off that a bit but want to hide this new building behind the existing barn. Just not attractive versus my looking out the back door at towering pines and the woods.
lots of errands to run, not an outside day for me. Back at it tomorrow. Going to start fairly early tomorrow with the chain saw cutting up lots of small trees removed from the woods for the path to the pond. The unfinished path...so much to do. The area where my woodsplitting operation is/was is exactly where I want the new building to go so time to get all that wood split, and cleared out of there. I don't mind running a chain saw in the 70's; much hotter than that and I don't last long.
have heard nothing back on the boat I'm looking at from the listing broker. Maybe my questions have bothered the seller.
   / Good morning!!!! #36,776
Coffee is done brewing. 69ー with partly cloudy skies this morning. Heading to 84ー with chance of thunderstorms. Off to the nursing home for a visit with my Mom. Then take car in for charging problems.
Looks like I lost all the well wishes I intended to send to David, Roy and others yesterday. Good news to all.
We Michiganders have a outlook of the states that may be different from other Americans. :rolleyes::D
Good Morning All.
   / Good morning!!!! #36,777
Will El Niño 2015 rival the strongest year on record? - CNN.com
lot of helpful info here, including a map of supposedly what's to be.
this sounds like California is in for some wet weather; hopefully not the mudslide type.
Wet and Cool. Well, probably good for growing crops...
Of course in the winter, it might mean snow here.
And it sure means I have to get going on digging drainage ditches around my orchard
with this forecast.
   / Good morning!!!! #36,778
Taken on a trip to Hawaii several years ago.
Roy G
   / Good morning!!!! #36,779
Roy G
thanks! You had a very nice room with a nice balcony. being a boater, I spent all my time out on those balconies. Something my wife liked, we went on about a dozen of them as annual vacations. What I particularly liked, having owned an old Bertram with lots of teak railings, was that big teak rail on the cruise ship balcony. On some ships it was nicely finished. I would wipe it down in the morning with a towel, and feel like I was holding on to my own huge yacht. Well, maybe after a glass of something...;)
wouldn't it be funny if David/Soldano's house was up on that hill behind you, in the fog... probably a different island altogether. Drew
   / Good morning!!!! #36,780
Good morning!˚ Whenever we start the morning off, before sunrise with 78˚ you know it going to get really really really hot. 78˚ heading way way way into the hundreds.
Last week I hit another 50hr marker on the tractor so maybe early today I'll change the oil - no need to warm the tractor.
We put the tents up yesterday evening up for the VFD fundraiser, 160'X20'. We started off with 6 people and a few more showed up after sunset. We have 8 large water fans ordered and one week to get the tables, benches, trailer stage, trash cans, parking barriers, restrooms, lights, cookers, and a few more small tents up. We also have to soak the ground with the firetrucks to keep the dust down.
Between the cooking/serving and the auction all personal and many community volunteers are kept busy so tomorrow we will help the neighboring VFD man their Beer Stand at their fundraiser and they will return the favor next week for us.
Ron, you are really going to mess Eric up.
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A51039)
2016 Kawasaki 70...
2006 Volvo VNL (A51039)
2006 Volvo VNL...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
196046 (A50459)
196046 (A50459)
