radial arm saw plasma cutter
   / radial arm saw plasma cutter #11
I like it. I'm thinking a couple of servos and another motor to turn the arm left to right and hook it up to a computer you could have a cnc table!
Think "etch a sketch"
yeah i foot pedal is a great idea, i'll have to figure an easy way to pull the trigger, i don't want to cut into the wires
   / radial arm saw plasma cutter #13
A light weight spring clamp over the switch would be a quick way of hands free. Use one of the plastic ones that has a space in the middle that it closes on the jaw tip without excessive pressure on the switch
   / radial arm saw plasma cutter #14
So I don't know how much the effort will or will not pay dividends to you down the road, but gosh durnit that's clever as stink!
   / radial arm saw plasma cutter #15
"The more I thought about it, the less enamored I was with the idea. (Sorry, Shiny Steve)"
No apology necessary Terry - the more I thought about the hurdles in the project, the further down the list it went :rolleyes:
So far, I've ended up with a Flange Wizard circle cutter/roller support and a known straight piece of 1" angle for most things, and Masonite patterns for the trickier parts.
Once I get the "sea box" placed I'll be moving all my welders and the big 700# (3'x7'x1") table into that, and I'm considering a "flip up" grate hinged off the big table for cutting... Steve
oh ya, thats a good idea, thanks. i think a bike cable will be fine to operate it
   / radial arm saw plasma cutter #17
I guess I should reclarify my previous post. I think the concept is great, especially for repeatable cuts but not worth the effort to build for my usage.
I'll probably build a freestanding table for my plaz and oxy/acet cutting.
Terry
Terry
yeah i suppose i just depends on what kind of stuff ya build. for me, i find i use wood templates quite often, so this was one way to use less of them
   / radial arm saw plasma cutter #19
Any photos of what you make?
Terry
Terry
well, off hand a have these. i make quite a few ice shack wood stoves from 20lb propane tanks, and the guitar is an art piece i made for my uncle as well, its made from 1/8 plate all welded and cut using wood templates
Kubota BX2230D (A47384)
Kubota BX2230D...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
STORAGE FEES (A52576)
New Edco Hand 12" Post Hole Digger (A50774)
New Edco Hand 12"...
Cat 277 Skidloader (SALVAGE) (A50774)
Cat 277 Skidloader...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
2020 Caterpillar...
