jwmorris
Veteran Member
- Joined
- Oct 3, 2007
- Messages
- 1,079
I have built straight line devices out of drafting slides and such before but having it driven is what gives you the largest advantage.
For short cuts like a radial arm saw would give you I just put a section of cold rolled steel in my homemade pantograph, any straight edge will do. The best templates are made from metal because you don't have to hold anything but wood and plastic also work.
Saves lots of time making duplicate parts as well but it is a lot faster than CNC for even a single part.
This is a 1" plate steel bracket I cut with it.
It is setup for a oxy/act in the photo but remove two bolts and the plasma torch drops into the cup (above the torch tip) and is held in by the hose clamp.
Also makes irregular cuts simple.
