Kioto dk40se electrical parts/issues
   / Kioto dk40se electrical parts/issues #1
Kodiak45
Gold Member
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
I have briefly read some of the electrical issues with these tractors.. I just purchased a 2009 dk40se and I absolutely love it. I have noticed that the headlight switch/turn signal switch isn't perfect and if you don't get it just right then the lights wont come on. I assume a new switch will resolve the problem. Is there any place I can order parts from online? I don't feel like going to a dealer way down the road if I have the option of ordering and paying a little shipping. I have also noticed that the ignition switch will occasionally not engage when turning the key as it appears to travel past the ignition point just by a little. Both of these seem like minor issues although they can be annoying, but I just hope I can find the parts online somewhere or even a wiring diagram would be great. Anybody know how the headlamp switch is attached...?
   / Kioto dk40se electrical parts/issues #3
If your 2009 is like my 2011 you should be able to pop out the switch. I often knocked mine out be accident until I cut off the turn signal lever as shown in this thread:
http://www.tractorbynet.com/forums/...206080-my-dk35-modifications.html#post2363466
Removing the clam shell for the ignition switch is trickier but koua gave the solution in this thread:
http://www.tractorbynet.com/forums/...286824-kioti-dk-throttle-lubrication-pix.html
I could not figure how to disengage the top clips but remembered his thread, which likely prevented me damaging the clips.
   / Kioto dk40se electrical parts/issues #4
A shot of fluid film in my ignition switch fixed it a couple of years ago without replacement. I wonder if a shot in that lamp switch would fix it too if you could get it in there. All of those switches would be easy to replace, but I would try lubing them up first.. Just the way I roll.
Thanks for the help guys. I'll try the lube first
What is fluid film? The local advance auto guys looked at me like I was crazy
Never mind... Google found it at lowes!
Isn't this equivalent to wd40?
   / Kioto dk40se electrical parts/issues #9
FF is a lanolin based lube/protectorant You can buy it in many places. It is good for a lot of farm/tractor related applications. I keep finding uses for it. Most of the Lowes now carry it, as supposedly the John Deere dealers.
If you can't find it locally you can buy it from Amazon. But it should be a bit cheaper locally. I first heard about it years ago from the DR. power equipment people. I finally asked for a sample from the manufacture and have been hooked on it ever since.
Amazon.com: fluid film
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
