Good morning!!!!
   / Good morning!!!! #36,951
65F @ 6:00 AM. Sunny. High 92F. Winds S at 5 to 10 mph.
That's a funny story about the plastic bags, Eric. The PO (previous owner) of the bike used plastic bags, too, but this time 'round everything has been in the bag that was needed, even if it wasn't clear at first what it was for. To sometimes compound the mystery, there were duplicates of certain components, gas caps for instance, often of different vintages which may or may not work. But more cut-and-try eventually led to a workable solution, and since this isn't a concourse class restoration, that's good enough.
The recycling places around here are getting to the point that they won't take anything that doesn't have a redemption value associated with it. If I try to recycle milk cartons, glass wine or olive oil bottles, or steel cans, they just point me to a large dumpster. Apparently the waste streams are bursting at the seams for metals, plastic, and glass, so unless the law mandates recycling, these outfits would just as soon avoid the cost of having the other stuff hauled off by discouraging people from bringing it in by not paying anything for it.
David, good progress on the MIL's road trip. Any particular reason she's not flying? Or was it just more practical to drive so she could bring more of her belongings with her?
RS, I once purchased a used Harbor Freight parts washer that had been used with one of those water based cleaners. It tore the pump up so bad I had to replace it before the darn thing would work, and even then it wasn't up to the task. That's when I learned Stoddard Solvent was the way to go, and let someone else struggle with HF's miserable excuse of a parts washer. And if you don't like orange counter tops, just stack enough stuff on 'em so they disappear! :laughing:
Drew, good you're bringing the tappet noise to the dealer's attention now in case real trouble starts later. Make sure they note the complaint on the work order for the oil change though. You might get an argument about changing the oil early, even if you're willing to pay for it. As if 3500 miles is early, which it surely is for a synthetic oil, which shouldn't be used in a new engine anyway. In the good old days real break in oil was thin to promote wear as the parts wore off the high spots left from the manufacturing process. These days those rough spots aren't quite so bad, so manufacturers are doing away with the whole idea of break in. But they're not doing away with the possibility of swarf and other debris left where it really shouldn't be, so Luddites like me still drop the oil at 600 or so miles and cut up the oil filter to see if anything was caught. But I don't like to go to synthetic oil for at least 10K miles, and might even hold off until 20K just to make sure that the rings have a decent chance of seating. Mainly I wait until the engine's not using any oil between changes (at 5,000 miles) before going to synthetic.
Lots of talk about misbehaving chainsaws today. When I hear thoughts like that I always wonder how much of it is due to carburation issues, either misadjusted, ethanol induced issues, or just plain dirty. More than once a carb rebuild kit has fixed the ills on the Stihl saws I use, and they were a whole lot less expensive than a whole new saw, even purchased at the dealer. Heck, letting the shop do the work would still be cheaper. As far as Echo vs. Stihl vs. Husky, I think it comes down to how long you plan on keeping the saw and how much you'll use it each year. A pro saw is designed to be used a lot each year, so materials are better and tolerances are held tighter so parts take longer to wear out. But you pay up front for that extra quality, and when things do eventually wear out, you pay a little more for the parts, too. A consumer saw will last just as long, but only if it gets only occasional use, and repeated all day use might even cause a failure. Farm and ranch saws are somewhere in the middle, and are a better match for someone heating with wood. But no saw can resist the ravages of ethanol, and draining them of fuel after use is always a good idea, even if using E0 fuel. And unfortunately at some point every manufacturer stops making replacement parts for old saws, so unless you plan on stockpiling, eventually we're all forced to upgrade at some point.
Don, you're fortunate to live in an area with such a colorful past. Especially since the stories are handed down through the families, members of which are still around to tell them!
I did come up short a square nut and a few sheet metal screws yesterday, but that was more my fault for not writing the shortfalls down prior to the last trip to the dealer. Worse, yesterday's tire delivery contained one of the wrong size, and on reviewing the order on the company's web site, they actually specified two tire sizes for that particular part number. Then on double checking what the manufacturer actually specifies for the machine, I ordered the wrong size to begin with. In this case two wrongs didn't make a right, but I was still able to convince the customer service rep to send out the correct size at no additional cost. No real harm done, but it'll be another week before the thing is ready to go. But at least for now I can move on to some maintenance work on other bikes, clearing out the last obstacles to starting again on the worlds longest lasting rebuild on one of the two old dualsport BMWs. That will involve some painting, and now that the weather's cooling off a bit, the timing might even work out.
TGIF:drink:
   / Good morning!!!! #36,952
I've never used water-based cleaners in my Tool Gypsy parts cleaner (same as Harbor Freight) ... just K-1 kero ...
I'm only on the second pump (after 15 or more years), even though the pumps are not rated for (petroleum) solvent-based cleaners. Go figure.
I'll probably source a good quality pump when this one ends up biting the dust.
LOL ...
I can't really complain - mine has served me well for the most part. The legs on it (thin sheet metal) are pretty questionable IMO (hence the idea of using the Safety Kleen drum as a base)
That will be no problem I'm sure ... ;)
   / Good morning!!!! #36,953
73°F and .35 inches rain since midnight.
Mom mobile is 3/4 way thru NM, great progress.
In town for Breakfast and errands
Be safe
Have a great day
Sent from my iPhone using TractorByNet
   / Good morning!!!! #36,954
RNG: David, good progress on the MIL's road trip. Any particular reason she's not flying? Or was it just more practical to drive so she could bring more of her belongings with her?
Actually, several.
One Dr said something in Mom's blood level was low and recommended against flying until it was back up.
SIL Frances had flown out to NJ from AZ, SIL Myra from CA. Mom decided she would give Son, Paul, her car. Made since to drive the car across country, loaded with whatever, then ship the car from CA to HI. Cost savings of shipping car from CA vs NJ offset cost of the trip. It was probably a trip down memory lane at times as well.
<_UIImageViewExtendedStorage: 0x14fcf3b0>
   / Good morning!!!! #36,955
Actually, several.
You're last "great adventure" trip can be just as good as your first and perhaps even better as by then you know they are few and far between and are paying attention.
   / Good morning!!!! #36,956
2015-08-22, 0432
61 degree right now...high of 82 today.
Today's chores...first, our new dryer is being delivered today. That'll make the wife happy.
I'm going to get some more of that bamboo cleared out as I progress toward the White River. I'd really like a landscape rake for this job, but I haven't found a used one on CL.
   / Good morning!!!! #36,957
Eric, can't make a decision? Take the day off. :thumbsup::drink: :cloud9:
You are right, these are good days for putting the feet up with a book and listening to the radio. A pity I saw your advice too late for yesterday, can I try it today instead ?
When my wife asks "what have you got planned for today" - she always does - I can answer "I am working on something that Ron suggested". :)
   / Good morning!!!! #36,958
Good Morning, 74 going to 96 with a feels like of 106. Yesterday I got the one more tree pile out of the side field and into the sink hole and burned off. Today I hope to get the last one done. That will give me 2 pastures to plant winter rye with my Bahia.
   / Good morning!!!! #36,959
Good morning. Showers and then heavier rain later in the day.
I am having a little chainsaw envy when I read about those of you with big saws. I have a little 14" Stihl and a 16" Huskey that are perfect for most of my work, though occasionally down comes a big tree, with a radius much bigger than my saw bar. Yesterday I slowly worked my way through an old elm that has been obstructing a track far too long.
Quite pleasant cutting in the light rain - not too hot and kept the flies away.
   / Good morning!!!! #36,960
Coffee is done brewing. 58° with clear skies this morning. Heading to 81° with nothing but sun in the sky. Laid my mother to rest yesterday. Beautiful summer day.
Eric, here is a repeat of yesterday. :thumbsup::drink::cloud9:
Don, hope the VFD fish fry goes well.
David, best for your mothers trip.
Roy. I would loan you my rake.
Good Morning All.
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2010 LACROSSE LUXURY LITE TOURING EDITION TRAVEL TRAILER (A50854)
2010 LACROSSE...
